  1. Hi
    I use vegas 4, old but enough. I used it before the crash with XP, all was good. it worked perfect with the ezmaker.
    The HDD crashed so I have a new one with win7 32. It recognized the card , no need to load the driver from CD.
    However. when I do capture video I get this note in the attched file.
    need help' thanks izzy
    Izzy Katz
    Oct 2005
    666th portal
    it doesn't look like that there was ever a win7 driver. the computer may know what card it is but not how to use it without a proper driver.
    http://www.avermedia.com/Support/Download.aspx?Type=Software&id=6&tab=APDriver
    Aug 2006
    I think we should find out which EZMaker capture device is being discussed. I found another device by that name, DVD EZMaker USB Gold, which does have Windows 7 drivers available. http://www.avermedia.com/product/ProductDetail.aspx?Id=188&tab=APDriver It looks like there are additional EZMaker capture products too.
  4. it is an old card, called ezdvd maker pci. Even no pro. so may be I have to go back to XP?
    Izzy
    Izzy Katz
    Aug 2006
    Izzy
    You have two choices. Find a new capture device with Windows 7 drivers, or go back to XP to use your old card.
