hi,
Does any body know how to make cce 2.5 sp version to open vaf file for multipass encdoing. vaf was created by CCE plugin
baskaran
It doesn't open it, it looks to see if youve already made one in another session. (The .vaf must be the same info as the clip you intend to resume)
Basically, if you do 4 passes, it creates the .vaf file, then does 4 passes. If you stop during the 4 passes, it doesn't have to make another .vaf file so long as it's the same as last time. (I hope that explains that)....
I'd suggest saving every session you do as a CCE project (.ecl) file, so if you have to dump out of an encode, you just open the project file again, click "ENCODE", and you should be good to go.
how to open rar file
By gary153 in forum Newbie / General discussionsReplies: 11Last Post: 29th Mar 2011, 12:39 -
.asf file will not open
By powrslave in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 11:56 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 10:25 -
cannot open file
By sharmine in forum Newbie / General discussionsReplies: 7Last Post: 23rd Dec 2007, 01:05 -
Open 00-file:s?
By Blå_Mocka in forum ComputerReplies: 7Last Post: 25th May 2007, 07:37
