Hello the community, I'd like to submit you an issue I got with a mkv movie.
Having got an italian version of 'Dragon trainer' in 3D version 1080p resolution, I got a 720p with an english audio track.
Both are playing fine on my Samsung BD-E5500/ZF player.
Wanting to keep the highest video resolution with an english audio track, I used MKVMerge to mix the best video with the preferred audio with no transformation nor re-encoding.
The result works fine on the PC but not with the BRD player. Audio codec seems no more recognized by the reader.
If someone can help....
Many thanks
pK
Be sure to disable header compression in mkvmergegui (file->options->disabale header compression...) and then mux your video and audio.
But it wouldn't play at all then...I guess.
Audio out-of-sync in mkv (MkvMerge)
By Sousa_Software in forum Video ConversionReplies: 8Last Post: 3rd Aug 2011, 17:00 -
Convert BluRay to MKV with MKVmerge no FPS set
By whachano in forum Blu-ray RippingReplies: 0Last Post: 23rd Feb 2011, 16:16 -
MKVmerge - stretch audio
By snadge in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 05:52 -
stretching 25fps audio to 24fps with mkvmerge
By deejay.2001 in forum AudioReplies: 0Last Post: 26th Feb 2010, 11:29 -
Smaller and cheaper Bluray reader later this year?
By Ollie6431 in forum Latest Video NewsReplies: 14Last Post: 27th Jan 2008, 10:13
