Page 2 of 2
FirstFirst 1 2
Results 31 to 35 of 35
  1. Originally Posted by jovopros View Post
    No, I think I might have not explained my situation correctly, the resulting audio is actually lower than the original: the VOB files are softer than the mkv. What I'm worried about is that the dynamic might have been changed or destroyed, that is, that the program just "normalized" the audio instead of applying something like "ReplayGain", which could just lower the volume of an audio file without changing the dynamic.
    If you have installed only ffdshow and no other AC3 decoders (like AC3Filter), then AVStoDVD takes care to properly setup the output mixer, thus channels and dynamic ranges are kept.
    If the audio has been lowered (don't know how), you can anyway tweak it using the Normalize option or the Amplify Audio option. Both of them works on all the channels, no risk to have them messed up.
    Bye
    MrC
    AVStoDVD Homepage
  4. @jovopros
    "keep dvd audio compliant" in 2.4.2 release is the same as "audio direct stream copy" in 2.5.0 Alpha release. In the newer release I have just changed the option label to be more clear.
    Bye
    MrC
    AVStoDVD Homepage
