A scripted way?
I use wavi to stream audio from AVS files to Aften to encode AC3, like this:
(the %1 is the avs filename)Code:for %%I in (%1) do ( wavi %%I - | d:\aften\aften.exe -b 128 -s 1 -w 45 -dnorm 27 - %%~nI.ac3 )
Get wavi at http://sourceforge.net/projects/wavi-avi2wav
I assume you could use ffmpeg to encode to AAC, it seems to do everything.
You could just use wavi to make a WAVE file and then convert that if you prefer, though I think streaming is more efficient. -
Or save (export) audio from Virtual Dub as wav then use any aac encoder You like to create aac file - later You can mux video with audio to required/proffered container
Shrink/alter timebase in AAC audio without re-encoding?
By Chug a Bug in forum AudioReplies: 1Last Post: 2nd May 2012, 14:00 -
Audio encoding AAC to AC3 for multiAVCHD authoring
By ejai in forum Authoring (Blu-ray)Replies: 6Last Post: 3rd Dec 2010, 11:00 -
Audio missing when opening an Avisynth script in WMP & VirtualDubMOD
By aln688 in forum Video ConversionReplies: 3Last Post: 2nd Apr 2010, 05:09 -
Any avisynth script for audio adjusting?
By flatbush in forum AudioReplies: 2Last Post: 29th Sep 2009, 15:37 -
Avisynth script problem (aac to wav conversion)
By greggery in forum Video ConversionReplies: 0Last Post: 22nd Nov 2007, 11:59
