I've got a bunch of NTSC DV footage that's to be converted to MPEG-1 using TMPGENC.
The image quality is great if I choose CQ, max of 5000, non-interlaced, no sound, and high motion setting.
Problem is, when these are viewed in Media Player the image doesn't change when I move the slider. Sure, I can change where the video will play from but I can't see the images. The file also starts playing when I've let up from the slider.
How do I set the encode so the slider works properly? I need both the "preview" as the slider is being moved and the ability to move to a frame and the file NOT continue to play.
Please ignore this post. I obviously had my head up my coodle as the files work. No sleep and looking at earlier versions from when I didn't konw what I was doing. Grr...
Mpeg2=>Mpeg1=>PowerPoint via TMPGEnc but weird DAR
By l-w-c in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 10:17 -
Avidemux lag after moving the slider
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 3rd Jun 2009, 11:30 -
How to make Keep V Flash Converter work
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 30th Nov 2008, 22:29 -
Power DVD - no 'click slider' in version 7?
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2008, 13:28 -
Color correction-slider for avisynth ?
By SerbianBoss in forum EditingReplies: 24Last Post: 6th Dec 2007, 17:12
