Hi,
i have another question. First does PSNR help in reducing banding?
Second, does demuxing audio and video streams cause a loss in quality when you merge them back together (i'm using Mediacoder to demux and MKVmerge to remux)
It's not something you "apply" to reduce banding. PSNR is a type of objective " quality " measurement , Peak Signal to Noise Ratio . Higher values indicate more signal, less noise. Thus, videos with higher PSNR should exhibit less "banding" if the banding was from poor compression, compression artifacts. But there are other types of "banding". Videos with high PSNR values will still exhibit "banding" from low bit depth
No, not if you demux and remux. Streams are just copied.Second, does demuxing audio and video streams cause a loss in quality when you merge them back together (i'm using Mediacoder to demux and MKVmerge to remux) -
Issues demuxing VOB w\PGCDemux & VOBEdit
By kpic in forum DVD RippingReplies: 15Last Post: 2nd Oct 2012, 04:39 -
Demuxing & recontaining
By videohalp in forum Newbie / General discussionsReplies: 5Last Post: 11th May 2012, 08:52 -
Help with colour banding...
By FNi in forum EditingReplies: 6Last Post: 2nd Oct 2010, 21:15 -
Banding
By Benus in forum Video ConversionReplies: 12Last Post: 5th Oct 2009, 16:10 -
DVD Lab Pro 2: Demuxing errors & Chapter Inquiries
By evilpr in forum Authoring (DVD)Replies: 8Last Post: 22nd Jul 2008, 03:40
