I've got some raw .dv footage - I want to apply a load of filters to it in AVIDemux, but AVIDemux only accepts Type 2 DV files.
I've searched and searched, but cannot find anything to convert it on a Mac. Anyone got any ideas?
Can it be done in ffmpeg?? Anyone have the correct command I'd need if so?
Am I correct in thinking that AVI will just be the wrapper, and Type 2 DV will be the codec? I don't want to lose any quality in the conversion.
Thanks!
Open your DV movie in Quicktime7Pro. Export as AVI using DV codec. It should make it Type2 automatically. Read my past posts about QT and Dv types 1 and 2...
Scott -
There is no quality loss, type 2 just interleaves the audio
You can search for type1 to type2 dv converting software, there used to be a bunch of free ones (I think ulead made one)
I'm pretty sure ffmpeg will do it (output will be type2)
ffmpeg -i input.dv -vcodec copy -acodec copy output.avi -
Something went wrong then. It should be a few% larger, certainly not double
Double check the ffmpeg log and commandline
Under stream mapping it should say "copy" , if it doesn't then it might be re-encoding it
The speed is more dependent on your disk IO speed. That's usually the bottleneck. If you read from one drive and export to another drive it will be faster -
In the commandline it says:
Input #0, dv, from 'Testttt.dv':
Duration: 00:01:26.6, start: 0.000000, bitrate: 28800 kb/s
Stream #0.0, 25.00 fps(r): Video: dvvideo, yuv420p, 720x576, 28800 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Output #0, avi, to 'Test01.avi':
Stream #0.0, 25.00 fps(c): Video: dvvideo, yuv420p, 720x576, q=2-31, 28800 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Nothing that specifically confirms 'copy'. ??
Raw DV vs. Type 2
By jlorelle in forum Newbie / General discussionsReplies: 21Last Post: 13th May 2013, 00:50 -
Best way to convert VOB to AVI or other type without any quality loss
By mikej411 in forum Video ConversionReplies: 4Last Post: 16th Nov 2011, 12:56 -
Easiest way to convert and mux audio to raw avi
By mukluk909 in forum AudioReplies: 4Last Post: 30th Nov 2010, 03:08 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
Best raw capture file type
By tomarwater in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2010, 01:31
