I'm under the impression the slower the speed setting the more accurate the decisions and the smaller the file size..Here's my dilemma--My faster settings are producing smaller file sizes and I can't figure out why, unless I'm just wrong..Not that its a big deal..More of a curiosity I guess.Testing was done on the same source using the 3 different settings...And I tried the same settings on other movies as well, encoding 3 times with the settings to see maybe if it was a fluke, but got the same results.. Medium setting would always be about 3 gigs larger than the fast setting and around 5 gigs larger than the faster setting..Doesn't make sense to me...The settings are the same...I only change the speed...I understand it makes adjustments to the settings when you move the slider, but shouldn't the medium setting make a smaller size?
Last edited by headhunter03; 2nd Sep 2012 at 12:33. Reason: Clarify source material
"numerous movies"? Was this testing various settings on the same source? Because different sources will give different filesizes because of different content complexity
But that's the general trend but there are exceptions. On some sources it is very linear relationship, on others one setting might be deviated from the trend for whatever reason. -
It's just a general trend - you usually get smaller filesize at higher preset settings at the same CRF value .
But often there are "out of place " results. If you search many people "complain" about the same thing
eg.
http://forum.doom9.org/showthread.php?t=163754
The size itself is meaningless unless you measure quality in some manner (eyes preferrably, but you can use objective measures like SSIM, PSNR as well)
Moreover you will see the "rank order" will change on different sources. You tested only 3 sources, but if you test a dozen more you will see the order swap
Compress videos from FRAPS into smaller files-sizes
By torchi12 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2012, 21:38 -
Alternative to HuffYUV for VHS capture.. Need smaller file sizes
By HDClown in forum Capturing and VCRReplies: 19Last Post: 16th Sep 2011, 15:48 -
How can I compress my captured videos to smaller file sizes?
By matta2k in forum Video ConversionReplies: 5Last Post: 6th Apr 2011, 08:31 -
Higher resolution sizes than 720x480 on MeGUI?
By Umandsf in forum Video ConversionReplies: 2Last Post: 4th Apr 2010, 08:10 -
re encoding MKV files with subs to smaller file sizes with min qual. loss
By malakov08 in forum MacReplies: 1Last Post: 4th Apr 2009, 03:06
