Now that I have learned how to get VirtualDubMod to display subtitles I now want to know how to get some of them removed. It's now easy for me to put both subtitles and a VOB into the editor. But whenever I try to make a video clip from the VOB or a full video conversion of the VOB, the subtitles do not adjust their timing. Even if you edit a video with hard subtitles, the soft subtitles somehow make it with the video and display with the hard subtitles. Is there any way VirtualDubMod can appropriately adjust the timing of subitles without using the ghetto method of manually changing the timing in a notepad?
Edit: Solved it. Move the .srt file away from the video and VideoLan Player will avoid playing both subtitles.
Results 1 to 1 of 1
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Audio Issues Preventing DVD Authoring of DVD Files
By larrytxeast in forum Authoring (DVD)Replies: 0Last Post: 12th Aug 2010, 16:23 -
corrupt video file preventing authoring?
By feh in forum Authoring (DVD)Replies: 3Last Post: 15th Feb 2010, 14:41 -
Preventing DVDFab HD Decrypter transcoding (shrinking) your files
By mazinz in forum DVD RippingReplies: 4Last Post: 30th Jan 2008, 19:08 -
Subtitling. Thanks in advance.
By shr3dd3r in forum SubtitleReplies: 4Last Post: 11th Sep 2007, 15:21
