My apologies if this has been answered before...I looked around and couldn't find anything that addressed this.
I'm trying to clip out a small portion from a dvd I've ripped to my computer. The segment is about 1 1/2 minutes long, from the middle to the end of a currently existing cell. I've tried several different methods: cutting half the cell, splitting the cell and then blanking the second half, using the "cut" command for the second half the of cell, and using the "keep" command for the first half of the cell.
However, in each of these circumstances, whatever program I'm using to play the file crashes if I try to return to the dvd menu after the edited point of the film (This happens both on digital files and the burned disk version of the files).
I'm kinda lost onto how to fix this crashing issue. Does anyone know what's causing this/how to repair it so the program doesn't crash?
Thanks in advance!
	Look into Womble MPEG Video Wizard DVD. You can mark In and mark Out, then cut out the unwanted selection. Very accurate. Don't know about the crash issue, but if you want to edit your video. There should be some guides on Womble, Google will help with that. I'm using it as we speak. I use VobBlanker, but have never cut cells, etc. Just blanking and skipping. It Started In Texas
  DVDlab PRO : Motion menu, cells, missing button highlights !By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 12:14
  VobBlanker substituir o menu/How to replace DVD menus with VobBlankerBy escarlate in forum Authoring (DVD)Replies: 24Last Post: 31st May 2011, 02:52
  One subpicture overlay across menu cells? - DVDLab ProBy nostrum in forum Authoring (DVD)Replies: 0Last Post: 8th Feb 2010, 11:36
  VobBlanker to Keep Original MenuBy sambat in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2009, 11:06
  VobBlanker DVD Split- Automatically jump to Split TitleBy src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
