  1. I currently use Ulead VideoStudio4 to capture DV from my camcorder through a firewire card. I see a lot of comment on VirtualDub. Will Vdub capture DV via a firewire card? (it seems to have some advantages).
    Thanks.
  2. I've tried Vdub DV capture with firewire card and it's ok. Try it. :lol:
    Canada
    It works only if you have a DV codec for "Video for Windows" which is the older video support method under Windows. If you have only "Windows Driver Model (WDM)" / DirectShow it won't work.
    Best way is to try it.
    Allan
    Jul 2001
    Maryland
    I can';t
    I get a screen of gray and red pixels.
    Also Virtual Dub hates DV Type 1, which is what most capture programs use.
    Canada
    Try the Scenalyzer Live Trial. I did after seeing rave comments for it and I bought it! Works really well! (actually I think I have a flaky Firewire card but still...)
    It produces Type-2 which feed nicely into VirtualDub
