I know what "Video aspect ratio" is, and i know what "Pixel aspect ratio" is too, but I can't understand why "Pixel aspect ratio" is needed? There are many TVs that have not 1.000 "Pixel aspect ratio", they have stretched pixels instead of square pixels. non-square pixels represent image stretched and ugly, disfigured. (I hate stretched and non-natural images)
Well, I think that only video aspect ratio is needed for image presentation, and pixel must be necessarily square. what would you say about it?
thanks...
If you really knew what they were, you would not post such rubbish.
Non-square pixels only exist AFAIK for dvd-playback. They are there to ensure that your 720*576 pixels correctly display for either a 4:3 image or a 16:9 image.
The stretching that you refer to is probably the result of not displaying a 4:3 image as 4:3. People do not like the left/right borders so 'stretch' to compensate and 'fill' the screen'. -
What you say is incorrect. Non-square pixels are used in most SD digital video standards and even for HD on occasion.
You're confusing badly set up televisions with pixel aspect ratio.
Take a typical example; 720x576 16:9 SD video. If you get out a calculator you'll see that 720x576 won't give a 16:9 image (assuming square pixels). That's because the pixels aren't square. They need to be stretched horizontally to get a 16:9 image with the correct proportions.
You can ask why 720x576 is used instead of 1024x576 (which would be 16:9 square pixel) - that would be a valid question. -
More info:
https://forum.videohelp.com/threads/323530-please-explain-SAR-DAR-PAR
A simplistic overview; A standard definition camera creates a 16:9 video which then gets distorted/squashed to fit a 720x576 frame. This gets transmitted digitally on satellite, cable or stored on DVD. Then when the video is viewed, a TV should see the embedded aspect ratio information and un-distort the video to the correct proportions. It's at this point that the pixels effectively get stretched and become rectangular.
Changing pixel aspect ratio of video clip?
By Real Ramona in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jan 2012, 11:20 -
Pixel Aspect Ratio in virtualdub
By wabsnazm in forum Newbie / General discussionsReplies: 6Last Post: 10th May 2011, 16:57 -
pixel aspect ratio?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Aug 2009, 14:53 -
Can an S-VIDEO lead send a 16:9 pixel aspect ratio
By kevthedrummer in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2009, 11:02 -
Aspect Ratio: Pixel AR and Display AR
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 18:42
