I'm studying a document PDF with Foxit Reader and I want to make some annotations to it. I don't succeed because it is secured. How can I make a copy non secured where I can write something? Or then how can I alter that attribute?
If someone gave you such a file to study, ask them for the password and you can then change the file.
Or try the tools here: http://www.cs.cmu.edu/~dst/Adobe/Gallery/
Otherwise, if printing the file is allowed, if you "print" to a new PDF file (several free PDF printer drivers can be found, if you don't have Acrobat), then you will have an unprotected PDF. No guarantee it will look exactly the same, but again worth a try.
I find I get better results often if I print to file using a postscript driver, then use Acrobat distiller. -
or buy a password recovery program from elcomsoft
or use anybiz soft password remover I have the old version it is fast and convenient i use it all the time never let me down, it is now acquired by wondershare http://www.anypdftools.com/
It's a professor's personal site, see http://www.cs.cmu.edu/~dst/
He's pretty critical of things like DMCA.
secured internet connection
By abdosagor in forum ComputerReplies: 24Last Post: 11th Apr 2012, 11:03 -
eBooks to .pdf?
By rotuts in forum MacReplies: 8Last Post: 23rd Oct 2010, 03:59 -
PDF file help
By jyeh74 in forum ComputerReplies: 14Last Post: 11th Jun 2009, 00:45 -
jpeg to PDF is OK! But PDF to jpeg?
By bryankendall in forum ComputerReplies: 2Last Post: 14th Sep 2008, 16:53 -
I have a secured DVD, and want to copy it to another DVD
By Xp4nd3r in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2007, 11:52
