I have used VLC for years because of its flexibility - will play almost anything regardless of zones, etc. But the computer in my classroom has a Chinese OS - XP and VLC will only install in Chinese. Their forum uses the Walter Cronkite response, "well, that's the way it is"... is there a program (hopefully free) that is equally as flexible as VLC that allows me to control the language that I will use with it? I just need English - don't need to change midstream.
Hi
SMPlayer is OK.
"Package with installer: smplayer-0.8.0-webdl.exe (9.32 MB)"
From here ---> http://smplayer.sourceforge.net/
Can choose language during install.
Also use option "MPlayer Components > Binary Codecs".
That is so stupid. I have no idea if it will be better, but the portable version of VLC might at least ask you what language you want.
http://portableapps.com/apps/music_video/vlc_portable
VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+
By Baldrick in forum Latest Video NewsReplies: 63Last Post: 23rd Feb 2014, 21:34 -
itunes replacement
By angryassdrummer in forum Portable VideoReplies: 2Last Post: 11th Apr 2011, 02:56 -
Looking for a replacement
By Peacedog in forum DVD & Blu-ray RecordersReplies: 7Last Post: 2nd May 2009, 18:13 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 11:57 -
Stage6 Replacement
By acid_burn in forum Video Streaming DownloadingReplies: 6Last Post: 3rd Nov 2008, 01:09
