Does anyone know of a solution to the problem of I am having? I am attempting to go to a particular part of a video on my ipod touch, and when i take my finger off the screen after moving the slider on the video progress bar, it either goes forward a bit, or backwards a bit. Anyone know of a solution to fix it where it will stay where i need it to be at? Please advise.
Was the video shot WITH the iPod or did you re-encode another type of video to play in your iPod?
hi. It's a video i got from online, and converted it to play on my ipod touch.
hi. I found the video online, downloaded it, and re-encoded it to play in my ipod.
And?
That's it?
That's all the information you are willing to provide?
Goodbye. -
Sorry I did not add more to my earlier post. Anyway, I downloaded the video from YouTube, and when I go to a certain part of it on my iPod touch by sliding my finger across the progress bar,I normally can go to a particular part of the video, and when I let go of the progress bar, it should let me play at that moment on. Instead, I pull my finger away, and it goes wild, sometimes a minute or two before or after that moment in the video. I am just wondering if there is a simple fix, either by modifying the video, or a way to prevent that from happening in any other videos I convert.
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 12:30 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
? Re-encoding Just Part of a Video
By Synetech in forum Video ConversionReplies: 12Last Post: 23rd Jan 2008, 02:27
