    May 2009
    Eh. So I have an MKV I made a while ago using either MakeMKV, MMG, or a combination of the two. It was made from one of my blurays, so every track is of course fully bluray compatible. What I want to do is basically the opposite of what MakeMKV does: Convert the MKV back into a BDMV structure - something that just plays when the disc is popped in.
    I tried my hand at MultiAVCHD but it remains a little counter-intuitive. Despite my having specifically told the program not to transcode the MKV in question (via the Transcode button), it seems to want to do it anyway. But I can't tell for sure, because once it's done, it has in fact generated no files at all and the app remains stuck in a semi-frozen state.
    Alternatives?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Alas multiavchd is abandonware, no longer updated so that might be part of your problem.
    Try bdrebuilder. Though I don't have a bluray burner so I have no bluray authoring experience to offer. However I have made my share of avchd discs, close but not the same.
    Edit - sorry disregard bdrebuilder. Apparently it is the bluray equivalent of dvdshrink, meant to transcode an existing bluray to fit single layer bluray discs. I'm afraid I don't have a recommendation right now. However if it is truly bluray compliant any real bluray authoring program should accept it as an input source. You would then be able to build a new bluray from there just as if you had a mpeg2 video and were trying to author a dvd.
    Nov 2003
    West Texas
    tsMuxeR is what you need. Set output to Blu ray disc.
    Nov 2003
    West Texas
    And if you just want a harder way of doing it, you could demux the mkv file with mkvtoolnix + MKVExtractGUI-2, then use the audio and video streams as input for EasyBD Lite. Always good to have options.
    May 2009
    Thanks, all. Yes indeed, options are the antidote to the unexpected impasse.
    Edit: Such as the apparent fact that Tsmuxer doesn't know what to do with certain kinds of audio track.
    May 2009
    And EasyBD Lite doesn't seem to like DTS-HD MA either. Neat.
    May 2009
    Alright, I've tried converting the DTS-HD MA to a wav file and EasyBD is still not happy. Just what will it take to turn this MKV back into a bluray?
    Nov 2003
    West Texas
    Glitches are a way of life in video it seems. Try using ClownBD, using the MKV input option, and convert the DTS-HD MA audio to AC3.
