Would anyone know why i get static in the sound recording every now and then? Ive tested different recording and the static does not always come at the same time. I have 2 new vc500 cards and they both have the same problems. I have reinstalled the plugina aswell as my sound card plugins. I am working on a fresh install of windows 7 sp1. I have tried both EZ grabber and showbiz software with the same problems. it record fine beside of the sounds statics.
Does anyone has a clue?
jp
I am having the same problem only with an imac OS X 10.6. has anyone found a solution? I'v been looking everywhere and the company suport is pretty non-existent. Any help would be great.
I too say it's the tracking on your VCR. I had this problem a while ago with one particular VCR. You track it for video, the audio sucks. You track it for audio, the video sucks. (This was one of the many problems I had with this VHS capture project over the years.)
If this is your case, just capture it twice, once for optimal video settings, the other for optimal audio settings, or use a second VCR if necessary to get the best of both - then edit/mux the resulting streams on your PC.
Honestly, looking for the optimal tracking for both audio and video will likely lead to major frustration - I gave up on it. There are methods available in software-land to clean the audio, but it will be better if you can correct it in the analog stage. If a second capture is all it takes, do so and be done with it.
I hate VHS. I always did.Last edited by PuzZLeR; 18th May 2014 at 08:50.
I hate VHS. I always did. -
No not tracking. I have the same problem when using 'other' video sources. I've found other forums were this problem has been addressed but no solution. I find it happens on longer recordings or if I do a lot of short ones. If I let it rest for a bit or re-boot the software (sometimes the computer) it improves for about an hour. I have a lot of stuff to record and this is not going to get the job done!
A bad wire in the VC500's audio cables or a bad wire in the RCA cable from your source?
Diamond VC500 One Touch Capture Device problems
By ZEROthefirst in forum Capturing and VCRReplies: 18Last Post: 26th May 2015, 14:35 -
Diamond One Touch Video Capture VC500 questions
By Hans L in forum Capturing and VCRReplies: 23Last Post: 19th May 2012, 15:38 -
VC500 No Audio
By Firelance in forum Capturing and VCRReplies: 3Last Post: 24th Feb 2012, 17:49 -
Diamond Video Capture VC500 Problem + Settings
By Firelance in forum Capturing and VCRReplies: 1Last Post: 18th Feb 2012, 04:04 -
Removing Delay from Diamond VC500
By shinderhizzle84 in forum Capturing and VCRReplies: 4Last Post: 27th Jul 2010, 11:49
