I've been trying to work on editing some MP4 files and clean them up. I'm using a copy of Sony Vegas Pro 9.0 that's fully updated. For some odd reason when I open or import the videos there is a strange audio glitch showing up where it will play fine for 29 minutes, and then for another 29 minutes it will repeat the first second of audio. Then after that it will do the same thing over and over playing the first 29 and then doing the second repeat. I have no idea why it's doing this and it's driving me crazy because I can't find a solution anywhere. Does anyone have any ideas what's going on?
Results 1 to 12 of 12
It is a MP4 with AAC-LC audio or something else? And if it is AAC-LC is it 2.0 or 5.1 or what?
Download and install a program called MediaInfo
Load the file into that and switch to TEXT view. That shows you all the info you need. You can even post that here (in fact I suggest you do that)."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
General
Complete name : C:\(Yeah you don't need to know this)
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 579 MiB
Duration : 3h 11mn
Overall bit rate : 423 Kbps
Encoded date : UTC 2012-07-16 18:00:10
Tagged date : UTC 2012-07-16 18:00:10
Video
Format : AVC
Format profile : Main@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=5
Codec ID : avc1
Duration : 3h 11mn
Bit rate : 290 Kbps
Width : 768 pixels
Height : 432 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.029
Stream size : 397 MiB (69%)
Title : Procaster Video
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 3h 11mn
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 175 MiB (30%)
Title : Procaster Audio
Language : English
Tagged date : UTC 2012-07-16 18:00:10 -
Well I don't see anything weird about the video nor the audio in this file. Seems pretty standard for a MP4 file.
Not sure why you are having a problem with it. Only thing I can think of is that you are using Vegas Pro 9 and Sony is up to Vegas Pro 11 now so maybe Version 9 can't properly handle MP4 files? I don't know.
I would try to convert the audio to a standard PCM WAV audio file and then load that after you load the video and basically use the PCM WAV audio file instead of the audio file that is muxed in with the video. See if that works.
tsMuxeR can demux the audio stream from a MP4 file. You can then convert that to WAV using any number of free tools."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I just loaded a MP4 file with filename.mp4 into tsMuxeR and it was able to demux the audio and it was the same kind of AAC-LC audio. Either you aren't doing something correctly in regards to tsMuxeR or the file is somehow corrupted.
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
Problems conveting several file types like RMVB and MP4 etc
By tommyleepark in forum Newbie / General discussionsReplies: 6Last Post: 21st Aug 2009, 18:55 -
Yamb - Problems While Splitting the MP4 File
By Cunhambebe in forum Newbie / General discussionsReplies: 11Last Post: 25th Jun 2009, 22:58 -
Problems converting MP4 video file to DVD.
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 6th Oct 2008, 18:26
