I have a video file (an .avi to be exact) with:
Resolution: 1280x720
Video Format: XVID
File Size: 650mb
I have good knowledge in converting video files using ffmpeg, my question is: is there a way to lower the file size without changing the quality of the video? I'm ok with any video format. Can you please help?
No. Any conversion to a lossy codec will cause the quality to degrade. You may not be able to tell, but it's a fact. Now, can the size be decreased with little change in quality? Yes, and maybe so little you can't tell. Try converting to x264 with either the original audio, or AAC.
I know nothing about ffmpeg, but there are plenty of programs out there that will take an XviD AVI and convert it to x264.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
Conversion
By kazz0817 in forum SubtitleReplies: 4Last Post: 28th Jun 2009, 13:20 -
.TS or .TP conversion
By joepic in forum DVB / IPTVReplies: 4Last Post: 22nd Jan 2009, 13:22 -
no sub after conversion
By volam in forum Video ConversionReplies: 0Last Post: 5th Sep 2008, 14:31
