Hi,
I have no experience of video editing (just graphic design!) but have a video that has a FRAME around it. I would like to use this frame on other videos, which are currently frameless. I only have the frame attached to a video and NOT separate, which Im sure would be easier
Thanks..
Any help would be appreciated!
By "frame" - Do you mean external border ?
If so, you can cut out the middle (either in photoshop or video editor) , so it has alpha channel, then overlay that onto the new video
You might need to do something differently if the videos are different dimensions or aspect ratios
Since you know about graphic design, it might even be easier (and better quality) to make the border from scratch to use as an overlay
Key framing so easy a 10 year old can do it
By TreeTops in forum Off topicReplies: 4Last Post: 7th Aug 2012, 00:13 -
Best Application to capture video from Component/S-video video inputs
By techspark in forum Capturing and VCRReplies: 17Last Post: 8th May 2012, 17:09 -
Photo Framing Software?
By Kamaljeet Dhiman in forum ComputerReplies: 2Last Post: 28th Dec 2010, 10:36 -
Edited MPEG2 Files Retain Distorted Vertical Framing Upon DVD Burning
By cyberboy in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 20:13
