Hi, was wondering if anyone could help. My problem is when I download videos from YouTube or anywhere else I get 2 files ones a meta file and the other won't play. This has been going on for a month now I've tried reinstalling realplayer a couple of times and have the same problem. It used to work fine until a month ago I don't know what's happened. I don't know wether this could make any difference a month ago I downloaded an application called gimp 2.8 photo suite could any of the files from gimp be clashing with realplayer files it just seems a bit of a coincidence that when I downloaded gimp, realplayer doesn't work properly.
Any help would be really appreciated as I am keen to get this sorted.
Cheers...
firefox with the downloadhelper plugin works well to download videos.
The best advice you will get is to abandon RealPlayer and use something else, like VLC or MPC-HC. I haven't installed RealPlayer on ANY computer I've used in some years now. RealPlayer is pretty fussy and yes, it is possible that something in Gimp is causing you problems, although I would certainly blame RealPlayer for that.
It's not always possible to easily download some YouTube videos. I've used StreamTransport to get a lot of them but even it doesn't always work. If you want to learn a lot about RTMP streams you can use various free programs, but if I find something that StreamTransport can't handle, I just use Replay Video Capture to record it. -
I agree with jman ... realplayer ain't so hot ... except I don't like mpc-hc. SMplayer is my favorite, then vlc. Either will play about anything without needing codec packs. VLC is known as the one that plays anything but smplayer is better there. it has the best video filters too.
RealPlayer Downloader
By oicram in forum MacReplies: 0Last Post: 15th Oct 2011, 12:14 -
Using RealPlayer on XP vs Win 7
By solarblast in forum Software PlayingReplies: 5Last Post: 10th Jun 2011, 09:06 -
Pb watching WMP / realplayer on TV
By siljan in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2008, 04:26 -
convert to Realplayer with Premiere?
By rocko918 in forum Video ConversionReplies: 0Last Post: 16th Jan 2008, 11:30 -
Time disparity with realplayer
By subsync in forum Newbie / General discussionsReplies: 1Last Post: 11th Dec 2007, 13:48
