I want to capture my VHS videos and convert to DV. I have done it in the past, using my VHS VCR and Canonon Legria with relatively good results.
I have read that the best is to use a Super VHS VCR for playback, although the videos are not Super VHS.
I have advertised and can get this one for next to nothing, but I'm not sure if this is a Super VHS machine:
"a LG TALKING VCR, 6 HD, hi-fi Nicam , looks like the model is a GC990EW. Has NTSC playback"
After Googling it, I am not much wiser.
Any advice please
Results 1 to 10 of 10
no there is no s-vhs marking on that vcr.
The rule of thumb I would go by is this:
Use a S-VHS vcr when you have an S-VHS recording, or when you have an otherwise ALL S-video capture chain (as the S-video electronics should be better on an S-VHS deck than a standard VHS deck). Or if the headgap (or TBC, comb filter) specs are so much better for your particular tape than other vcr alternatives.
If you just have a regular VHS tape, and only go out via composite video (to WHATEVER capture, DV, Analog, etc), then you aren't getting any benefit.
Scott -
My situation is as follows-
I have yellow and white RC connection points at the back of my VCR. No composite connection.
So, if I understand correctly, I will get a benefit when using S-VHS, which will have a composite connection. Is this right?If you just have a regular VHS tape, and only go out via composite video (to WHATEVER capture, DV, Analog, etc), then you aren't getting any benefit.
Just another question- is it worth my while to try to get a S-VHS; in other words, is the quality really better? But I must say, these tapes are very valuable, so any bit of quality in the image gained, will be worthwhile -
yellow rc connection is in fact composite white is sound and it goes in audio card or audio in tv card.I have yellow and white RC connection points at the back of my VCR. No composite connection.
All Svhs units have svideo out where vhs machines have only composite ( like in your case ) so svideo is better connection all along then composite http://www.hardwaresecrets.com/article/157
also svhs units have in general better transport mechanism and have extra processing ( tbc noise reduction and so on ) which will make better and stable picture even from old vhs tape.
So generally speaking find svhs unit for your valuable tapes
Can your capture method use an S-video input? If not then you won't gain anything from an S-VHS machine. Please note that S-video connections are not the same thing as the S-VHS tape format.
i don't know any tv card or dvd recorder that doesn't have svideo ( which of course is not the same as svhs tape format) inputCan your capture method use an S-video input? If not then you won't gain anything from an S-VHS machine. Please note that S-video connections are not the same thing as the S-VHS tape format.
Yeah keep in mind, the SVHS decks (at least, the suggested ones) aren't valuable just for the improved connection, but more importantly for the other features of the VCR. How much value those features will be to you will depend on your tapes, but buy one for the potential of those features, not for the connector itself.
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 06:10 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19 -
VHS Head Cleaning -- How do I know if the VCR needs it?
By KeepItSimple in forum RestorationReplies: 20Last Post: 23rd Mar 2008, 22:10
