I shoot on sony's a77. Everytime I switch cards and format my a77 starts counting again at 0. So if during the course of a day I fill up 10 cards, all the files on each card will have the same name making editing according to when the shots were taken an exercise in furstration. I need a way to be able to take these files and put them all in one folder and rename them according to their timestamp. Does anyone have a clue how to do this or something like this that'll allow me to be able to access my files according to when they were shot? Thanks
Do the files not have a date and time assigned to them at time of writing that shows up in Windows Explorer in the "Date Modified" column that you can simply use to rename the files manually, or are you not viewing them in Windows?
When my frieds using other cameras import into the same folders the file naming doesn't reset, so it's just one after another. This is a huge advantage. I need to figure out how to get my files organized by time. Any ideas?
have you checked the manual? most cameras have file naming options in their setup menus.
I have checked the manual AND the camera. File structure is set to series as it should be. There isn't an individual setting for video files, and this setting only seems to affect picture files.
If you want to bulk rename the files in each of the folders so that you can then move them into a common folder, Total Commander has a very effieient and flexable renaming function. It is free with a very simple nag-screen or low cost without it. Has lots! of other uses and I much prefer it to Windows Explorer.
Andrew Jackson: "It's a poor mind that can only think of one way to spell a word."
reorder streams with ffmpeg issue
By MarquisdeOz in forum AudioReplies: 6Last Post: 9th Jul 2011, 13:19 -
Dye-based vs metal-based: which will last longer?
By RedZone in forum Authoring (Blu-ray)Replies: 11Last Post: 11th May 2010, 21:30 -
Way to Export song files based on Playlist?
By denzlite in forum AudioReplies: 1Last Post: 4th Aug 2009, 17:58 -
lost timestamp on tod files
By mpunt in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2009, 15:49 -
Web based player for playing large files?
By Joe_Dean in forum Video Streaming DownloadingReplies: 2Last Post: 6th Jan 2009, 20:25
