I have two different DVDs of the same movie, in one of them the movie is in PAL format, in another, it is in NTSC. I want to gift this movie to a friend. Which one affords better viewing pleasure, PAL or NTSC ?
Results 1 to 10 of 10
Why do you ask ?
Ooops ! I am sorry ! I think I didnt explain my problem clearly. I will put it this way. I have two DVDs, one of which has 720x480 and another 720x576, which correspond to NTSC and PAL. FPS is also different, 29 fps and 25 fps. The DVDs obviously came from different relatives in the UK and the USA. Now when I want to back it up, which one should I prefer ? I guess if it is an action movie, I should backup the NTSC and discard the PAL DVD or if I want image clarity, I should back up the PAL and discard the NTSC. Is that the correct judgement to make ? -
The correct judgement would be to use the one that's native to your local standard, IMO.
Sometimes a DVD transfer of a movie can vary greatly from one release to another but if the quality of the transfer used is about the same then you probably won't see a big difference between them. Of course you can argue that PAL has slightly more resolution but I'd argue that the frames per second speed up is annoying.
The best thing to do is watch both, try to get an idea of which looks better. Also it makes more sense to go with PAL if that is your TV type than NTSC. Just as it makes more sense to go with NTSC if your TV is NTSC. Of course many people have DVD players that can play both formats but again there's usually a trade off of some sort based on the type of TV being used.
So the answer is ... it depends. You can't categorically say one is better than the other."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
In India it'll be PAL.
You could check out your DVD on DVDBeaver (if they've reviewed it), because they usually check the differences between the different released versions for quality of transfer etc. -
Well I just found out that my relative has watched both PAL and NTSC format DVDs in his DVD Player and TV, so I can gift him any one of them. But I think I will gift him the NTSC one, coz I think fluidity is an essential ingredient in any movie watching experience.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
