I'm trying to play some Quicktimes with DTS audio using QT Pro for Windows, and I'm getting no audio. Is there a codec or a Windows equivalent of Perian I can download?
Before anyone asks, I'm using QT Pro rather than a different player because I need to export sections of these movies and QT Pro offers the best export tools that I'm aware of. If anyone can suggest an alternative Windows app that will offer the same export flexibility and also cope with DTS audio, then I'd be very interested to hear about it.
It needs to have a basic timeline like QT Pro from which I can set In and Out points for defining the section to be exported, and preferably also the ability to enable/disable the individual audio tracks, so if I want to export with just the centre channel enabled, I can. Thanks!
FWIW, you can play DTS in QT for Mac if you have Perian installed. I'm playing a QT movie with DTS audio right now, as it happens.
I was trying to help out a colleague who only had access to a Windows machine, but since there appears to be no Windows equivalent to Perian and no native Windows apps that will play QTs with DTS audio *and* replicate the export flexibility of QT Pro, he's been able to wangle use of a Mac. Having to transcode before exporting would have got old very quickly, so he can do what he needs to do in a single step now. -
I believe that's only because Perian has calls to ffmpeg (which has a lib that supports DTS). No, there is no Windows-equivalent to Perian for QT.
Most Windows users bypass QT altogether when playing media and use either DirectShow-based apps, or use self-contained apps that have their own libraries (like VLC).
However, you are incorrect: using ffmpeg (and other apps) one can easily rewrap QT to other types which are both DTS-playable and flexible in exporting.
And your college (edit: sorry should read colleague) is STILL not doing it in a single step, as he/she has to get the file to the Mac & back, eh?
Because of Apple's attitude towards PC's, there never HAS been, never still IS (and probably never WILL be) parity between what QT is capable of on a Mac and what it's capable of on a PC. No ProRes 4:4:4, No AIC, etc.
ScottLast edited by Cornucopia; 28th Aug 2012 at 18:54.
Best Blu Ray Player to play 3D MKV (DTS audio) files off my USB HDD?
By Freaz in forum DVD & Blu-ray PlayersReplies: 18Last Post: 28th Apr 2012, 23:15 -
Play DVD Audio in QuickTime for Windows?
By seskanda in forum Software PlayingReplies: 8Last Post: 17th Mar 2012, 02:11 -
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 04:50 -
Three audio tracks play simultaneously in Windows Media Player.
By bizzybody in forum Newbie / General discussionsReplies: 6Last Post: 18th May 2009, 02:39 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 07:12
