After i render my video, every spinning text has a top and bottom border that spins along with the text. When i open Sony Vegas 11 and check the clips, everything looks normal, i play frame by frame and nothing shows up. Any one have any ideas? My Project Properties are : Width:1,920 , Height:1,072 , 30 FPS, 8 Bit, Aspect Ration 1.0000 Render settings Width: 1920 Height: 1080 , 29.970 (NTSC)
Results 1 to 11 of 11
Does it looks ok in the vegas preview before rendering ?
Can you post a screenshot or sample clip or at least provide a better description? Are they compression artifacts ?
What codec did you use? What bitrate? Try increasing the bitrate
Not that it's related, but was project properties height a typo ? 1072 ? not 1080 ? -
it does look normal before i render it. this is one screenshot http://i48.tinypic.com/2rrt4oz.jpg , http://i45.tinypic.com/m915e8.png , after i render it, it looks like this http://i45.tinypic.com/3480cp2.png , http://i45.tinypic.com/2wgrbxj.png , it was basic text spin, and someone told me that 1072 was also good cause it was divisible by 16 or something like that.
If you use AVC, internally everything is padded to 16 anyway. Just leave everything at 1080, including project properties, render settings, all generated media and assets.
Maybe the black edge pixels were caused by that? If your overlay layer was 1072, those 4+4 pixels on the top and bottom might show as black pixels instead of alpha channel
HA: _Al_ beat me to it
I am rendering that small 30 second clip with all 1080 to see how it works, Nope it still shows up there.
ok so now that i changed it to 1080 i can see the lines in Sony vegas , i just need to figure out why the lines show up.
Do a quick test with a new project, everything new at 1080 , with a quick text spin - there shouldn't be any black lines
It might be reusing using old render previews -
I am making a new project really quick with those settings. so far so good. let me render it really quick
Yes it worked, ok so putting it to 1072 really screwed me over, not listening to that youtuber lol. thanks again all
Sony Vegas Pro Black Screen Rendering
By JasonQuinn1992 in forum EditingReplies: 6Last Post: 2nd Jul 2012, 12:55 -
sony vegas pro 8 rendering wont render video just audio and text
By bahlue18 in forum EditingReplies: 6Last Post: 12th Apr 2011, 07:31 -
Sony Vegas pro 9. Rendering Black screen
By jolehoz in forum EditingReplies: 0Last Post: 15th Nov 2010, 11:02 -
Rendering MPEG 2 in SONY VEGAS PRO 9
By sfalcon in forum AudioReplies: 1Last Post: 21st Feb 2010, 16:07 -
Sony Vegas 8 Pro rendering problem
By windyangel in forum EditingReplies: 1Last Post: 16th Jul 2009, 02:00
