Several years ago I used a software called "DVD Decrypter" to copy DVD movie to my harddrive. It has created 4 files. Now I want to combine & and make the movie on Harddrive but it does not seem to work. Can any one tell what DVD Decrypter really do to DVD movie and how I can play it back. Thaks
Your post is very unclear about what you want to do. If you want to play it back as a DVD, then decrypt it in File Mode (not IFO Mode) and double-click on the VIDEO_TS.IFO using Media Player Classic Home Cinema or other similar players. I suspect you're just double-clicking on a VOB. That plays a VOB, but not the DVD.
If you want to convert it to something else (an XviD AVI with MP3 audio, for example), then you have to use a program (one such as AutoGK) that can do it. -
I cannot play those files. I need to use DVD Decrypter to make the video file. Is there a way I can check file format. They have no extension. There are 6 files. Please help.
If there are no extensions, then you turn on extensions in your operating system.
http://www.terryscomputertips.com/computers/hidden-file-extensions-in-windows/
Earlier you said there were 4 files.There are 6 files. -
We can't help much without more info.
Please list the files (and folder they are in) WITH EXTENSIONS SHOWING turned on.
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 14:48 -
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 14:11 -
DVD Decrypter from one pc to another
By jwedge in forum ComputerReplies: 3Last Post: 26th Jan 2008, 23:35 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 22:39 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 16:55
