Hi. Normally, I split with either avidemux or boilsoft but both fail me with this file. (It loads OK with avidemux but crashes as soon as I press play.) Possibly my splitters just don't like big files, as this one is. Can anyone suggest an editor that could handle these file specs?
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 3.17 GiB
Duration : 1h 2mn
Overall bit rate : 7 207 Kbps
Writing application : Lavf52.93.0
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=30
Codec ID : avc1
Duration : 1h 2mn
Bit rate : 6 800 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.109
Stream size : 3.10 GiB (98%)
Writing library : x264 core 107
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=2 / weightb=1 / open_gop=0 / weightp=0 / keyint=30 / keyint_min=16 / scenecut=0 / intra_refresh=0 / rc_lookahead=30 / rc=abr / mbtree=1 / bitrate=6800 / ratetol=1.0 / qcomp=0.60 / qpmin=1 / qpmax=31 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Thanks in advance.
Results 1 to 9 of 9
Hi
mkvmergeGUI has...
Code:Global > Splitting > Enable splitting... > After this size/duration
No freeware will give you frame accuracy over start/endpoints
videoredo beta, solveigmm video splitter -
Noted. When I said 'total control' I didn't mean 'total control' (ahem...). With avidemux you have to start at a predetermined frame but can end on an exact frame. That's good enough for me. However, MKV doesn't seem to give good control of either end. But it does what it does and it'll do when all else fails.
No you can't . You can only cut on keyframes in avidemux (start and end points). You might have "lucked out" that the end point was a keyframe in that case
All Long GOP compression formats limit you to not being able to pick the exact start or end frame - you can only cut on keyframes. Thus it's not frame accurate
"Smart Rendering" means the keyframes within the GOP of the cutsite are re-encoded , but the rest of the video is untouched. Thus you can have frame accurate start/end points . Videoredo and SolveigMM smart render AVC
vdub and avidemux can smart render mpeg4-asp (divx, xvid), but not other formats -
Maybe we're at cross purposes here. With avidemux (which I use for avi and mp4) I always use the double-arrow keys when selecting Point A (the edit will fail otherwise). But I can stop playback WHEREVER I like and that will quite happily become Point B.
Yes, the double arrow << and >> keys navigate by keyframes
You should check your older edits, because they probably have errors on the end - Point B won't be where you think it is unless you happened to be on a keyframe
But if your video used all keyframes (all I frames), then it doesn't matter where you cut (everyframe is a keyframe)
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 18:00 -
HELP! Convert new file to work on old server.
By NP1975 in forum Video ConversionReplies: 4Last Post: 15th Feb 2011, 17:52 -
Arrgh.. "Easy Video Splitter" doesn't seem to work with Windows 7
By Wakewatcher in forum EditingReplies: 10Last Post: 14th Jan 2011, 22:19 -
Gabest MP4 splitter vs. Haali Media Splitter
By jaduvil in forum Software PlayingReplies: 4Last Post: 16th Jun 2010, 11:57 -
Vob file doesn't work, but it used too
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2008, 06:47
