I need to upload videos on youtube.
I have DvD which has .Vob files. I want to Join and then Cut the videos without Conversion/Loosing quality. Please tell me how to do it ?
Results 1 to 21 of 21
Regret is unprofessional.
It's right there in the link I gave you:
Tools
Some authoring and editing tools can import DVD VOB files directly and reauthor and reedit it:
TMPGEnc DVD Author (editing and authoring)
Ulead DVD MovieFactory (editing and authoring)
Ulead DVD Workshop (editing and authoring)
DVD-lab (no editing only authoring)
MPEG Video Wizard(no authoring only editing)
VideoRedo (no authoring only editing)
Pick one and try reading just a little bit. -
As near as I can tell he just wants to cut VOBs from a DVD and then upload them to YouTube as-is - no reauthoring, no reencoding. It's a very poor idea, especially so given the very poor quality of Pakistani DVDs (interlaced and field-blended) but if all he wants is a VOB cutter, then I might suggest MPEG2Cut2 or its earlier (and easier to use) MPEG2Cut. For joining maybe VOB2MPEG or VOBMerge.
these are the aspects of my video. please suggest me some expert advise.
General
Complete name : D:\Entertainment D\Entertainment\1407,Difaa-e-Shaan-e-Siddiqu-e-Akbar wa Faarooq-e-Aazam R.A\1\NEW\VIDEO_TS\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 1h 20mn
Overall bit rate : 1 770 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Duration : 1h 20mn
Bit rate mode : Variable
Bit rate : 1 511 Kbps
Maximum bit rate : 1 950 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.146
Stream size : 874 MiB (85%)
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B, BT.470 System G
Matrix coefficients : BT.601
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 1h 20mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 130 MiB (13%)
MenuRegret is unprofessional. -
I was only speculating before but can now say with confidence that what you have is pure and utter garbage. If you'd like to give us a good laugh, please upload a small piece of a VOB now that you know how to cut them. MediaInfo can tell only a small part of the story.
What advice were you looking for? How about, "Delete it from your hard drive as soon as possible". Is this the retail DVD, or something you downloaded from someone that ruined the original even more? -
it's a retail DVD. don't know what you are talking about. i need suggestion/tips. don't waste my time if u don't have suggestion other than deleting it.
read my question again,
i want to Merge/Join .Vob format file and then need to Split/Cut without loosing quality or conversion.Regret is unprofessional. -
So I guess you were too busy to at least give a quick look at the link I put up earlier?
https://forum.videohelp.com/threads/169081-How-to-convert-DVDs-back-to-MPG-files-for-re...thor-or-reedit
See the giant word:
VOB2MPG (DVD to one MPG file, FREE and VERY VERY VERY VERY EASY TO USE!!!) -
Read my answer again:
And also as I said before, just uploading a part of a crap DVD will look even worse on YouTube than it does on your TV set. There are ways to improve these things, ways that apparently don't interest you at all. At least you have a PAL version, so maybe it's not field-blended.Originally Posted by manono -
simpiles use DVD Decrypter to put files on your hard drive press decrypt and hey presto files are on your hdd use mpg2cut2 to cut one edit at at time to jion just use mpg2cut2 again add all the files and save this clip there you have it fast simple easy. dont let anybody tell you you need 100 tools to do an easy job slowly t shirt avalible saying plzz support mpg2cut2
i do not have DVD now. i have saved it's files in my Hard Disk. DVD decrypter is not accepting files from hard disk. i tried.
ok, what should i do now to merge and cut the video file , even though it's not original dvd, according to u ?
is it right way what i followed now ?
i. Merge .vob files with Mpeg2Cut.
ii. then Split it with Ultra video cutter with the settings i.e. output = Same as sourceRegret is unprofessional. -
step one use Mpeg2Cut to split useing ( I ) symbol in the prog for start point and end point output to where ever one clip at time then if you wish to merge just add clips in prog and use the save this clip option in mpeg2cut dont worry if it wont play in microsoft media player it will on youtube or Media Player Classic - HC will take seconds to do
its splits with accuracy here if I do one clip at a time if you try to out put more than 1 clip at a time you will run into trouble and I load the file again affter each clip as for auto set to size of clip im not sure I do it manually maybe you could make that point to the developers on there forum but as i said more than 1 clip at a time is not a good idea
If your channel is in good standing you can upload videos of any length:
www.youtube.com/watch?v=hRSEddrh7kc -
No problem bro as you probily relize now this is a gap in the market that most of the larg software companys are neglecting (wink) bang head here lol its like the old joke paddy goes up to boss and say's my wheelbarow is going squeak .........squeak ........squeak boss says your payed off paddy asks why boss says because it should be going squeak . squeak . squeak
How do I edit, cut, join DVDs, VOB, VIDEO_TS folders
By Baldrick in forum Authoring (DVD)Replies: 14Last Post: 8th Dec 2025, 11:01 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 08:01 -
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 13:04 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 13:57 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 22:57
