Hi
I have a problem when converting a flv to mkv. The original FLV contains a .h264 file and a timecode.. but the video is in fact constant framerate (29.97003 fps)
Then I use mkv toolnix to put the .h264 file into a mkv container, set the framerate option to 29.97, and the video becomes 3 seconds longer than the original ! Btw, the 29.97 becomes in fact 29.97062... why is it different than 29.97003? But it doesn't explain the delay of 3 second (for a total length of 12 min).
Could you help me to fix this issue? I want to keep the original length because the audio progressively gets out of synch while playing the video.
No matter if I mux with the timecodes or not.. I always have a delay of 3 seconds
Can you please have a try? Here is the flv:
http://www.mediafire.com/?767kvf19p4ndt5u
You'll notice that the timecodes have a problem.. so it's necessary to remove the first lines.
I'll try with ffmpeg, but I kinda prefer the mkv... -
It works ok with the new flvextract (2.0.2) in sync. This new version can remux directly to mkv if you place mkvmerge.exe in the same directory as flvextract
I tried with flvextract 2.0.2. and direct remux with mkvmerge, but I still have this delay. Original video is 12:21.. remuxed video is 12:24
Difference bet FLV and AVI
By resmiac in forum Video ConversionReplies: 1Last Post: 18th Aug 2010, 07:42 -
mov to flv framerate issue with ffmpegx
By Sebbeto in forum ffmpegX general discussionReplies: 5Last Post: 23rd Mar 2010, 00:20 -
MKV framerate/Sync issue
By dragonkeeper in forum Blu-ray RippingReplies: 0Last Post: 14th May 2009, 23:14 -
How do I determine the framerate of an FLV file??
By lurky in forum Video ConversionReplies: 2Last Post: 13th Aug 2008, 00:13 -
mkv framerate issues
By Eric998765 in forum Newbie / General discussionsReplies: 1Last Post: 11th Mar 2008, 02:34
