Results 1 to 20 of 20
    Aug 2012
    Toronto
    I copied 2 .avi files to my PS3 for playback. AVI file [A] works. But AVI file [B] does not work. But otherwise both [A] and [B] work on my Win7 machine.
    I would like to analyze the reason why [B] does not playback on the PS3. What tools should I use to perform the analysis? What information should I be analyzing?
  2. mediainfo (view=>text)
    gspot
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Best thing to do is to copy the MediaInfo TEXT view output and paste it here. That way we know what video and audio codecs are being used and can tell you why it isn't working.
    Aug 2012
    Toronto
    General
    Complete name : E:\Movies\(A).avi
    Format : AVI
    File size : 1.36 GiB
    Duration : 1h 26mn
    Overall bit rate : 2 265 Kbps
    Writing library : AVI OpenDML FlasKMPEG plugin release
    Video
    Format : MPEG-4 Visual
    Format settings, BVOP : 1
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec ID : DX50
    Codec ID/Hint : DivX 5
    Duration : 1h 26mn
    Bit rate : 2 100 Kbps
    Width : 704 pixels
    Height : 352 pixels
    Display aspect ratio : 2.000
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.353
    Stream size : 1.26 GiB (93%)
    Writing library : DivX 5.0.2 (UTC 2002-05-16)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : MS Stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 1h 26mn
    Bit rate mode : Constant
    Bit rate : 160 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Stream size : 98.4 MiB (7%)
    Alignment : Split accross interleaves
    Interleave, duration : 209 ms (5.00 video frames)
    General
    Complete name : E:\Movies\(B).avi
    Format : AVI
    Duration : 1h 39mn
    Overall bit rate : 1 949 Kbps
    Writing application : VirtualDubMod 1.5.10.1 (build 2439/release)
    Writing library : VirtualDubMod build 2439/release
    Video
    Format settings, GMC : 2 warppoints
    Codec ID : DX50
    Duration : 1h 39mn
    Bit rate : 1 492 Kbps
    Width : 640 pixels
    Height : 352 pixels
    Display aspect ratio : 16:9
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.276
    Stream size : 1.04 GiB (77%)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : 2000
    Duration : 1h 39mn
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 320 MiB (23%)
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 500 ms
  5. Member FulciLives's Avatar
    May 2003
    I'm not sure but the 2nd one or the one labeled (B).avi says the following:
    GMC : 2 warppoints
    My guess that is why the PS3 will not play it and if I'm correct then you'll probably have to re-encode it or look for another version (see if you can find a MKV or MP4 version).
    Aug 2012
    Toronto
    I think you might be right. I did a search on 'GMC and PS3' and found a post in a different forum that also suspects that it might be the GMC. In the different forum post the GMC is set to 3 warppoints.
    Would it be against the forums rules to provide a posting link to a different forum in order to inject some more input into the topic?
    GMC : 2 warppoints
  7. I'm 100% sure PS3 cannot handle GMC (or QPEL)
    Most standalone DivX/DVD players cannot handle it either
    Aug 2012
    Toronto
    To add to what you said after further researching:
    ps3 will not play xvid with
    1) gmc
    2) qpel
    3) custom matrix
    4) max size 2gb
    also.. "audio split accross interleaves" seems to be accepted only sometimes ...
    Aug 2012
    Toronto
    From what I have been reading, a re-mux is the simply succussful solution.
    GMC : 2 warppoints
  10. Originally Posted by kingaddi View Post
    No, it has to be re-encoded
    Rewrapping (remux) it won't help
    Aug 2012
    Toronto
    https://forum.videohelp.com/threads/281819-Divx-Xvid-Converting-for-PS3
    1) gmc
    2) qpel
    3) custom matrix
    4) max size 2gb
    Aug 2012
    Toronto
    Thank you everyone for your fast responses. The problem is solved.
    Aug 2012
    Toronto
    You are 100% correct.
  14. Member FulciLives's Avatar
    May 2003
    If you need to re-encode then I suggest using x264 as that will help to reduce the loss when re-encoding. I would use HandBrake since it is easy-to-use. You can either pick MP4 output (converts the audio to AAC audio) or you can pick MKV output (which can use AC-3 or DTS but make sure you convert DTS to AC-3 in HandBrake) then use tsMuxeR to make the MKV into a M2TS file.
    The PS3 has native support for both MP4 and M2TS files.
    MP4 is x264 video with AAC audio.
    M2TS is x264 video with AC-3 audio.
    A MKV with AC-3 audio can be remuxed (without re-encoding nor transcoding) to a M2TS file.
    Oct 2007
    Running the avi through avirecomp would probably fix it too.
  16. Banned
    Freedonia
    Incorrect. As was clearly stated multiple times by multiple users the ONLY way to get rid of GMC is to re-encode. Period.
    NO standalone player has ever been identified that is capable of playing an AVI with a GMC value greater than 1 warppoint. When you have 2 and 3 warppoints then only a PC can play those. In early to mid 2000s even 1 warppoint would cause almost all players to barf, but in recent years various players have been found that can handle 1 warppoint. For compatibility reasons it's best when encoding to just avoid GMC and Qpel altogether unless you are playing on a PC and care nothing about media player compatibility or have established via your own testing that the player you are using can handle GMC and Qpel.
    Oct 2007
    avirecomp does Re-encode, with virtualdub and does a damn good job too. Thats why I suggested it. Here is the description from VideoHelp:
    "AVI ReComp can be very useful for users who want to clear their AVIs out of GMC or Qpel functions to prepare the clips for standalone DVD players"
  18. Member FulciLives's Avatar
    May 2003
    It's for playback on a PS3 so as I said the quality of the re-encode will be better if done using x264
    Oct 2007
    I hear ya but I was just throwing it out there.
