    Aug 2012
    OMAN
Name:	25-08-2012 00-02-57.jpg
    help me plz
  2. Member Trippedout's Avatar
    Aug 2012
    scotland
    Hi bro its probily your codec pack or badly render file to edit this type of file I use mpg2cut2 can be found under tools section and do one edit at a time from file to stop audio problems then I use winavi all in one to output to any format winavi is free to try and i couldent recomend the purchase of this software highly enuff I use codec pack xp I use xp pro operating system. this setup software and you will not have anyproblems this been my hobby for lots of years beleave me you wont get any better zidane all the best
