I wanna use Open VPN with xbmc , someone explain (as simple as possible) to me how to configure this thanks
So far i could connect to the YourFreeVPN (TCP) with the gui ( openvpn-gui-1.0.3.exe) that's it
I have also downloaded the plugin openvpn for xbmc
Results 1 to 1 of 1
Subs work in VLC but do not work in the DVD Player through USB
By faithhealer in forum SubtitleReplies: 4Last Post: 1st Jul 2012, 20:40 -
XBMC Alternatives
By AuroEdge in forum Software PlayingReplies: 1Last Post: 5th May 2012, 08:57 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Converting .TOD files for use in XBMC using FFMpeg
By duckredbeard in forum Video ConversionReplies: 9Last Post: 6th Aug 2010, 07:42 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11
