Hi everyone!
after 5 days searching I am totally desperate looking for a program that give me the chance to:
Convert audio without loosing video quality.
The program has to run on MAC (OSx)
The most useful I have found so far is D-Vision 3, but the limitation of this program is that it doesnīt convert MP4 and MKV files...
I have found other program MACX Video Converter, which looks like does what I want, but in the final video there is reasonable loose of quality...
So... Do you know any program that I could use??
OSX Based
Able to transform any audio to MP3
Without affecting video quality
and fast
Thank you so much!!!
PD, all this problem comes from my Picopix 2480 doesnt reads other audio than Mp3 and Wav![]()
P.S. In the future ANYTHING you post that is Mac specific needs to be posted in our Mac forum. Posts in the Mac forum show up on the main page with a special symbol marking it as a Mac forum post and we have members who specifically look for that symbol on new posts to see if someone needs Mac help. You post in another forum then there's no special Mac symbol and most of us can't offer much in the way of Mac specific help. Your post happened to be something I could answer.
have you tried normal h264/mp4 with aac audio? it claims to support the spec which includes aac. it also says mkv is ok so most likely it plays ac3 also. it's only separate audio only files that it needs mp3 or wav. i'd just make sure not to try dts in video files.
it claims? which program are you talking about?
ffmpeg, I have downloaded the program, but I canīt open it after installing it, I donīt know which is the problem...
thanks! -
He is talking about picopix.
I'm not very impressed with your lack of understanding so rather than insult you, I'm going to leave this thread. However, I will give you a final hint. I mentioned TWO programs you could try. If you don't have the skills necessary to install and use programs on a Mac then maybe you need to ask a friend with Mac skills to help you.
How to convert vob to avi without loosing video quality ?
By RON36 in forum Video ConversionReplies: 4Last Post: 31st Oct 2011, 09:56 -
Convert a 720p .mp4 file without loosing quality help
By Cupid Stunt in forum Newbie / General discussionsReplies: 7Last Post: 18th Jan 2011, 15:30 -
How we can remove commercials from a video cd without loosing quality.
By nusratjaveid in forum EditingReplies: 1Last Post: 4th Dec 2010, 11:17 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
how to convert mkv to divx/avi without loosing its quality?
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2007, 12:00
