    Aug 2012
    Denmark
    Hello.
    I have cropped 134 on to and bottum, but i want to keep aspect ratio 16:9
    So i need help to resize to the right resolution to keep aspect ratio 16:9
    sorry for my bad english.
    Oct 2005
    666th portal
    so you want to cut off portions of the left and right picture? 1920x1080 is 16/9 you can do the math your self if so. x/(1080-134)=16/9 then 1920 - x will give you want to cut off the sides.
  3. Member wulf109's Avatar
    Jul 2002
    HD TV's are 1:78 or 16:9 full screen. Most movies are shot in 2:35 AR which means they will display on your HDTV with black bars at the top and bottom. Do you want to make a 2:35 movie appear full screen without black bars?
    Aug 2012
    Denmark
    The movie is from a 16:9 bluray when i crop 134 on the top and bottom, it gets aspect ratio 2,35:1
    But i want to keep aspect ratio 16:9 without black bars.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the only way is to cut off parts of the picture on the left and right. or use the remote control and adjust the tv picture size which would accomplish the same thing.
  6. Originally Posted by AMDgutten View Post
    No you don't. It's an idiotic idea. You either crop (lose) about a third of the picture from the sides and keep the aspect ratio, or you ruin the aspect ratio by stretching it back out to 1.78:1. Don't do it.
    As aedipuss suggested, use the zoom on your remote control to see the damage it does.
    Aug 2012
    Denmark
    Ok, I drop the idea and just use 2,25:1
  8. I suppose you're making MKVs or MP4s from Blu-ray. You could use RipBot and have it automatically crop the picture (access it under Properties). It gets it spot on most of the time, but you need to examine the numbers and use the preview as well. Once in a great while, it will get the numbers wrong.
    Pull! Bang! Darn!
