I can use the old xvidvideo.ru builds no problem (latest version 4992), but if I try to update with any of the newer xhmikosr builds (latest vers 5857), I don't get centre channel audio playing? - (eg dialog). Nothing I can find in Options fixes this? I use 2 powered stereo speakers (no surround setup). What has changed/broken??
What audio decoder is in use? Right click on the MPCHC window while the video is playing, hover over Filters..., examine the list of filters in use. One of them will be the audio decoder. There will also be an audio rendering device. You can select them to change any options. Make sure your speakers are configured (Control Panel) for stereo, not 5.1 or other multichannel setup.
Sorry I never got back to replying... As you suggested, under Filters/Audio Decoder I simply had to enable "mixer" & select stereo output. Thank you jagabo.
MPC HC problems with 6-ch AAC audio tracks
By tufffta in forum Software PlayingReplies: 19Last Post: 1st Mar 2012, 04:47 -
Remove Small Section of Center Channel from Stereo Track
By EmpireStrikesBack198 in forum AudioReplies: 14Last Post: 31st Jul 2011, 13:48 -
Change channel on MPC from 4 to 3?
By cwb in forum Capturing and VCRReplies: 0Last Post: 1st Sep 2010, 16:45 -
Audio of Media Center TV not working until channel change / reboot
By matoind in forum Media Center PC / MediaCentersReplies: 2Last Post: 25th Mar 2010, 11:11 -
SpiderMan3 BD Backup - No Center Channel on PS3...
By mshilly in forum Blu-ray RippingReplies: 6Last Post: 18th Jan 2009, 02:49
