http://news.yahoo.com/sony-plans-launch-80-inch-led-tv-4k-153045301.html
So my question is when will those promised holographic discs be released to hold a 4k movie at hollywood quality? Hmmm?????
				Results 1 to 15 of 15
	For the benefit of anyone else who got as excited as I did when reading the thread title, they're LED-backlit LCD, not LED.
	Make that four or five years for me at THE LEAST
 Until 4k bluray players or whatever they'll be called are the same price as they are now for regular blurays than I might consider it. That would mean the sets are down in price than as well.
 Of course by the time that happens 8k sets will be coming out   Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	I just wonder when is it going to be enough... 100 inch TV?, 200?, custom wall to wall TV like Avatar?. 1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
	It will never be enough until we get either the matrix style interface (with saftey features of course) or we finally get a REAL holodeck. Until then SIZE DOES MATTEROriginally Posted by medico_brujo
 (of course not at the thousands of dollars it will take - I can wait)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	The higher the resolution, the bigger the screen must be, period.
 To me at least, the current business model is driving the video engineers and technicians INSANE
 Does the average consumer really need a video resolution as high as 4K (and/or above) ?????
 Also, H.265, H.2999 , whatever, for what ???  For broadcasting more garbage while using the same old bandwidth ? , whatever, for what ???  For broadcasting more garbage while using the same old bandwidth ?
	...or, unless in an environment where the viewing distance can't be conveniently changed, sit closer to take advantage of the increased resolution at the same screen size. It's not compulsory to have an enormous screen just because it has a higher resolution.
 I tend to apply the "30 milliradians of arc" rule to screen resolution versus viewing distance as the physical size of the screen bears no relationship to how much detail it can display. If a single pixel fills 30 milliradians of arc in terms of the viewer's field of view then this approximately corresponds with their threshold of detail discrimination if they have 20/20 vision.
 Sitting closer than this reveals individual pixels and gains the viewer nothing in terms of detail. Sitting further away than this loses the viewer the ability to discriminate down to the single-pixel level, thus wasting display resolution. The maths is simple enough to do and applies equally to all viewers assuming that they have either 20/20 natural vision or properly corrected vision.
 Present day Full-HD screens provide sufficient resolution to fill a relatively small field of view with as much detail as the human eye can discriminate, and this equates to an optimal viewing distance of roughly 1 metre for every 10 inches of diagonal screen size. The higher resolution of the '4K' panels increases the field of view the panel can fill whilst maintaining the same pixel density, but it can't improve on the crispness of a current Full-HD panel when viewed at the correct relative distance as the eye is already detail-saturated.
 Unless someone is already sitting too close to their current Full-HD screen, they're going to gain nothing in terms of image crispness by going '4K', assuming equal clarity source material, so don't go getting overly excited about uber-high res screens just yet.
	But this is about resolution not clarity isn't it? I mean you generally only have 1080p source material now so even if you have access to 4k material you can't compare the two in the "real world" until you have a 4k set with 4k material to compare the same material with 1080p material on a 1080p set. Ie if you had a movie shot in 4k and converted professionally to both 1080p and 4k and played each on its respective max res set.Originally Posted by slipster
 Then and only then can a "real world" comparison begin.
 Of course I'm just as happy using my 32" 720p hdtv. Of course I'd like it bigger (who wouldn't huh? ) but I make do with what I have.
						Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? ) but I make do with what I have.
	I guess it depends how you define each of those words. The newer panels may improve on other aspects too, but in terms of resolution, you do get to a point where more pixels equals zero visible improvement due to the limitations of the human eye. You can sit closer to smaller pixels to gain a larger field of view, but that's all the extra resolution gains you unless the previous lower resolution was inadequate because of too close a viewing distance being used for that resolution.
 Yes. That would lead to about as fair a comparison as you could have, but the point I'm making is that even if you have lossless source material at the native resolution for each of the displays, once you reach the point where the human eye can't discriminate any further detail (the 30 milliradians of arc rule), the rest is a waste. It's only field of view that increases as pixel density goes up once you've reached the saturation point, and we have that already with Full-HD unless people are sitting too close for the size of the screen.I mean you generally only have 1080p source material now so even if you have access to 4k material you can't compare the two in the "real world" until you have a 4k set with 4k material to compare the same material with 1080p material on a 1080p set. Ie if you had a movie shot in 4k and converted professionally to both 1080p and 4k and played each on its respective max res set.Last edited by Slipster; 26th Aug 2012 at 12:42.
	Oh wow an industry trying to sell us something we don't really need? What a conceptOriginally Posted by slipster
 (sorry not really being sarcastic at you just the whole hype and pushing extreme tech in general)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	For people with very long viewing rooms and very deep pockets it's not necessarily a waste. I'm just saying that the average Joe in an average size home (well, an average UK-size home anyway  ) stands to gain little if anything. ) stands to gain little if anything.
 I know. Join the club.(sorry not really being sarcastic at you just the whole hype and pushing extreme tech in general)
	Yep. Too bad though we aren't all millionaires and it would make a differenceOriginally Posted by slipster Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	If you compare current HD resolution to film, film has unlimited native spatial resolution. There are no pixels in film, so they decide the SPI when they make digital prints. Last edited by budwzr; 28th Aug 2012 at 13:02.
  Sony 65 inch Rear Projection HDTV suddenly displays red bandsBy daytonadvd in forum DVB / IPTVReplies: 29Last Post: 28th Aug 2013, 22:18
  SONY BRAVIA - 32" LED - Video play back issues from USB port.By iRecycle in forum DVB / IPTVReplies: 13Last Post: 10th Aug 2013, 03:15
  Led tv 32” sony kdl-32ex42By matrixnis in forum SubtitleReplies: 0Last Post: 6th Jan 2012, 09:41
  My 73 inch TV came in a 67 inch box. WTF?By dafoe in forum Newbie / General discussionsReplies: 74Last Post: 20th Nov 2010, 23:22
  Do lurkers only come out during the holidays?By Supreme2k in forum Off topicReplies: 13Last Post: 19th Dec 2008, 10:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
