Hello,
I have an anime with a interlace and noise problems. I have fix interlace using QTGMC but i can't fix the noise using DeNoise. Any help with the noise. please ?!
I have use this script:
Sample file:Code:LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\dgdecode.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\mt_masktools.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\RemoveGrain.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\mvtools2.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\nnedi3.dll") Import("C:\Program Files (x86)\AviSynth 2.5\plugins\QTGMC-3.32.avsi") AviSource("test.avi") QTGMC(Preset="Slow") SelectEven()
http://www.mediafire.com/?hndjhvixif5jdqh
Best Regards,
SB4
Results 1 to 13 of 13
McTemporalDenoise(). Use whatever preset you like. Or tune any of the settings yourself.
That clip should be inverse telecined, not QTMGC. Unfortunately, interlaced video was encoded with Xvid as if it was progressive so the chroma channels are screwed up.
x264 mkv attached.Code:AviSource("rTest.avi", audio=false) AssumeTFF() TFM() TDecimate() McTemporalDenoise(settings="very high")
If that's too slow for you try TTempSmooth() at its stronger settings.Last edited by jagabo; 21st Aug 2012 at 19:52.
Just as a side note:
it's not recommended to place many files into Avisynth's default plugin folder;
FWIW, I have only four of them to be loaded automagically:
The other ones remain inside an "AVSplugins" directory, and are called only when needed, of courseCode:08/09/2012 01:36 59,904 ffavisynth.dll 01/27/2010 10:10 26,624 DirectShowSource.dll 07/05/2005 13:04 7,129 colors_rgb.avsi 07/19/2012 01:09 73 ffavisynth.avsi
And it's not necessary to LoadPlugin() dll files, or Import() AVSI files, that are already in the plugins folder.
I have to load .dll files and import .avsi files manually because it dose not load automatically...
Thanks for the help guys... -
Thanks jagabo now it's work fine
I have one or two questions to ask. I want to upscale the video to 1024x600 and i have use the script below but the result i think need more sharpen and a little denoise. Is it right on i am wrong...?! How can i use eedi3 instead of nnedi3 ?
Regards,Code:nnedi3_rpow2(2) LanczosResize(1024,600) Sharpen(0.3)
SB4 -
That would be the wrong aspect ratio. The video is 4:3 DAR so you should resize to 1024x768. I would try something like:
Code:AviSource("rTest.avi", audio=false) AssumeTFF() TFM() TDecimate() Deblock() UnDot() McTemporalDenoise(settings="very high") LSFMod(strength=200) nnedi3_rpow2(2, cshift="BicubicResize", fwidth=1024, fheight=768) -
Ok, I do more test using NNEDI3 & aWarpSharp ( 2012.03.28 version ). Is this a good result or i used to much sharpen...?!
Code:NNEDI3_rpow2(rfactor=2,cshift="lanczosresize",fwidth=1024,fheight=600) aWarpSharp()
Yeah, I think awarpsharp() looks a little better. Also try going less sharp with nnedi3 (bilinear) and more with awarpsharp(). Or, since the video is sharper on the vertical axis than the horizontal axis (as with most video based sources), use a sharp resize for the horizontal, softer for the vertical:
I thought that looked better than the others I tried.Code:nnedi3_rpow2(2) LanczosResize(1024,960) BilinearResize(1024,768) aWarpSharp(depth=32)
Consider using Stab() to reduce the projector bounce.Last edited by jagabo; 22nd Aug 2012 at 00:25.
FrFun7 is good denoiser for anime. Also a line darkener like vmtoon - http://avisynth.org/mediawiki/External_filters#Linedarkening
Anime Video Lineart filter(s)
By Taichi in forum Newbie / General discussionsReplies: 6Last Post: 21st Apr 2012, 13:16 -
Fast denoiser?
By Mephesto in forum EditingReplies: 4Last Post: 10th Jan 2012, 21:32 -
Good anime sub sites
By Rippl in forum SubtitleReplies: 6Last Post: 1st Oct 2009, 20:03 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31 -
Need earlier versions of MSU Denoiser plugin for virtualdub
By cybertheque in forum Video ConversionReplies: 2Last Post: 15th Oct 2008, 16:32
