Hi guys,
So, I've set up a video wall of 3x3 (9 in total) fullHD LED TV's.
These are the specs of the computer running all the screens:
1 STK 650173 AMD FX-8120 8-Core Processor
3 STK 743942 PowerColor Radeon HD 7750 1GB GDDR5
1 STK 752104 Samsung SSD 830 Series 128GB 2.5"
1 STK 640645 Corsair Vengeance DDR3 1600MHz 8GB CL9
.. should be the most important details ..
So, what I now need help with is how to decode movies for these screens..
What resolution would be test to use for this? (and what can this machine handle?)
Bitrate? And codec? Never done this before, so I wanted to know if anyone here had any information regarding this setup.
We want to show different movies on each screen, and then flash them all and play one big movie across them all.
I would think the easiest way to do this is to just make it all in one movie (comp all the 9 movies together in a grid, and then play this move across all screens).
Because of the graphicscards I'm using, I can only combine 3 and 3 monitors in one displaygroup. Using VLC, I can then split the movie into 3 pieces (three 3x1 pieces) and fullscreen them on each of these 3 displaygroups. This is working, but a bit laggy? (any settups I should look at? Or maybe another video player would be better? One that buffers the video or something? This is all going to happen locally btw..)
Let me know if you need more information. I really need help on this!
Thanks! =)
Results 1 to 1 of 1
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
How can I tell which codec is being used?
By sasuweh in forum Video ConversionReplies: 4Last Post: 8th Nov 2010, 01:08 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
Is there a codec for this
By jakefree in forum Video ConversionReplies: 0Last Post: 13th Jan 2009, 22:19 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41
