Poll: What cooler do you use for your cpu?
Results 1 to 30 of 31
  1. I'm a Super Moderator johns0's Avatar
    canada
    I'm using a cooler master hyper 212 air cooler.
    Oct 2005
    666th portal
    Noctua NH-C14
  3. Member olyteddy's Avatar
    Dec 2005
    Stock Intel core i7.
    Aug 2012
    UK
    Arctic Cooling Freezer 7 Pro, but only because I overclock.
  5. Andy Samurai from Scythe
    Nov 2005
    CM Hyper 212
    Feb 2004
    Australia
    Arctic freezer 13 pro
  8. Stock AMD heat sink and fan on AMD AM3 955 CPU.
    I originally was using Arctic Silver 5 between the CPU and heat sink, a friend turned me on to Antec Formula 7 Nano Diamond Thermal Compound. Man if you ever thought the Arctic Silver was hard to apply you should try this stuff.
    It seems to keep the temperatures a bit more stable but not a lot cooler, only about 1 degree on average.
    --dES
    "You can observe a lot by watching." - Yogi Bera
    http://www.areturningadultstudent.com
  9. Banned
    Freedonia
    Stock AMD heat sink and fan on AMD Phenom II X6 1090T. This was my experience with this processor:
    I tried 2 different motherboards from Gigabyte and Asus (MUCH preferred the Gigabyte). The processor slot has very little extra space for a non-stock cooler and you need to understand that if you install a non-stock cooler, it may end up costing you 2 memory slots because it will overhang them.
    AMD policy is that non-AMD coolers void their warranty. Caveat emptor.
  10. Mod Neophyte redwudz's Avatar
    USA
    Corsair H-50 water cooler. It's doing a Handbrake encode at present at 70% CPU on all six cores at 43C.
    Sep 2005
    LOST in the USA
    I have no idea. My son assembled it for me. During summer, I just remove one side cover of the case.
  12. I'm a MEGA Super Moderator Baldrick's Avatar
  13. Anonymous
    Guest
    Zalman 9700 led on a Intel 8400 dualcore
  14. Zalman 7500 CU on a Phenom II 905e quad core. I've used variants of these Zalman fans on several builds, and find them effective and quiet, even at high CPU loads (the 905e is not a good example as it is rated 65 watts and rarely sends the fan above 1200 rpm)
  15. Stock Intel Retail box cooler. The missing option in the poll.
    If I'd known I was going to live this long, I'd have taken better care of myself.
  16. I'm a Super Moderator johns0's Avatar
    canada
    Nope,Active Fan Cooling.
    Aug 2006
    Stock AMD cooler. More aggressive cooling has not been needed so far.
  18. For some reason I presumed that active fan cooling ment a larger aftermarket cooler.
  19. I'm a Super Moderator johns0's Avatar
    canada
    Active fan cooling means its cooled by a fan as opposed to air cooled.
  20. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    I selected "water cooling" even though they are not really "water" but "Liquid Cooling"
    CORSAIR H80 With dual 120mm fans in push/pull setup for the O.C. 6 core 4.0Ghz.
    shameless bragging
  21. Is it quiet? That is one criteria for all my computers that must be met. Thanks
  22. Banned
    Jun 2004
    Mine is damn quiet!!!
    120mm fans move more air at slower speeds & less noise than smaller 80mm fans do at higher speeds with less airflow and more noise.
    With the 5 - 120mm fans & the 1 - 200mm side fan, this case is probably the quietest setup I have even owned......
    Barely hear a hum with it on.
  23. Less than meets the eye. Phlexor's Avatar
    Jun 2001
    Victoria, Australia
    Thermalright Ultra eXtreme 120 in push/pull on a Q6600.
  24. Originally Posted by Noahtuck View Post
    Which case is that? It looks good. My opinion is that a computer should be quiet enough that the only noise you hear is the hard drives seeking. Does the H80 keep temps down with the overclocking? Since my Computer sit next to the TV I want to be able to hear the quiet passages in video. I'm getting ready to upgrade from my I7 930, Sorry to ask so many questions. Thanks TB
  25. Banned
    Jun 2004
    It's the Rosewill Armor case,
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811147047
    Not sure where you can get them anymore.
    I bought mine last year.
    And for you to hear it running you would have to have super hearing and have your TV/sound system at like 1 to hear it over anything else!!
    LOL!!
    Mine is on my desk next to my monitor, less than 2 feet from my ear at pretty much head level.
    And with no sound what so ever from anything else, room fan, system speakers shut off, I barely hear it, it is very quiet!!
    I also run the fans for the H80 at full power and the pump at full power all the time.
    [Attachment 13617 - Click to enlarge]
    I have one of these case's for my quad core,
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
    which I use for my HTPC in my living room next to my 46" LED and I don't even notice/hear it running, but it also uses only 6 x 120mm fans with a Corsair H50 also in push/pull configuration with dual 120mm fans.
    The only thing comparable to the Armor case are these,
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811147157
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
    I just know I won't ever use anything that uses smaller fans than 120mm anymore as those things make way more mad noise with less airflow compared to 120mm & up.
  26. Banned
    Jun 2004
    Huh...
    for some reason that photo is not showing up for me, just say's Attachment 13617
  27. I'm a Super Moderator johns0's Avatar
    canada
    They are showing up now.
  28. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Using CM Hyper 212+ in 2 pc's.....with Scythe S-Flex F & G fans.....
  29. That is a nice looking layout and thanks for the links. I use Newegg a lot since Even with ground shipping most things ship from their warehouse a half hour away and I get them overnight anyway.
    That is one thing I did with the computer case I'm using now. I snipped the power wire going to the LEDs on the fans so they stay running and dark next to the TV, I also only plugged in the activity LED and not the power LED. Less distraction when it is running. I know it seems like a waste to have lighted fans and disable the lights but Bays and layout is the important thing.
    I use my TV as my display for everything. Cable and Satellite W/DVR TV, Media player, Computer, DVD recorder & BluRay player. That way I can start a video encoding or authoring and switch back to TV until it is done.
    TB
  30. Banned
    Jun 2004
    yeah the nice thing about those Armor cases is they have a switch on the top at the front that lets you turn the fan lights on and off while keeping the fans running.
