Hi guys,
I am currently trying to convert a batch of MKV files into AVI files for compatibility with my DivX Player. In order to prevent frame-rate lag issues with the audio, I have to specify a frame rate when re-encoding the files (As you guys have taught me a long time ago).
Anyways, I am currently using MediaInfo to pinpoint to frame rate I should use and I get two frame rate numbers to choose from.
Which frame rate should I use? Google hasn't been to kind to me when I was searching. I doubt re-encoding at 23.810fps or 24.000fps will make a big difference, but it's nice to know which is the correct approach.Code:General Complete name : L:\File1.mkv Format : Matroska File size : 149 MiB Duration : 23mn 50s Overall bit rate : 875 Kbps Encoded date : UTC 2011-04-05 18:38:03 Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 6 2010 16:18:42 Writing library : libebml v1.0.0 + libmatroska v1.0.0 Cover : Yes Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Codec ID : V_MPEG4/ISO/AVC Duration : 23mn 38s Nominal bit rate : 750 Kbps Width : 848 pixels Height : 480 pixels Display aspect ratio : 16/9 Frame rate : 23.810 fps Original frame rate : 24.000 fps Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.077 Writing library : x264 core 98 r1629 2e81ce1 Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=750 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=1927 / vbv_bufsize=1927 / ip_ratio=1.40 / aq=1:0.50 / nal_hrd=none Audio Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : A_AAC Duration : 23mn 50s Channel(s) : 2 channels Channel positions : L R Sampling rate : 44.1 KHz Resolution : 16 bits Text Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha
The way I think it works...
The frame rate is written to the video stream and also at the container level. After you've remuxed video while changing the frame rate, MediaInfo displays the original frame rate written to the video stream as "original frame rate". The new frame rate, after remuxing the video while manually changing it during the process, is displayed as "frame rate".
If the video in question doesn't have audio sync issues, you'd want to use "frame rate".
How do you go about specifying a frame rate when encoding? 99.99% of the time it's probably not necessary.
Frame Rate/23.976 vs. 29.97
By mltwitz in forum Video ConversionReplies: 11Last Post: 20th Dec 2012, 08:23 -
Frame rate
By eponarider1 in forum Newbie / General discussionsReplies: 13Last Post: 6th May 2012, 10:17 -
Frame rate question
By bergqvistjl in forum Video ConversionReplies: 2Last Post: 3rd Mar 2012, 18:09 -
Frame rate conversion help
By Og in forum Video ConversionReplies: 20Last Post: 8th Nov 2011, 10:56 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48
