usinc virtualdub and the mkv plugins, what combination would creat the smallest video file the fastest? (using the brightness/contrast filter)
I would use the xvid codec. And use the one pass constant quality/quantizer encoding mode (under video->compression->xvid codec->configure).
Using a Brightness/Contrast filter has NO effect on either filesize (smallness), or on speed of encoding.
(Unless you were to do the extremely foolish thing of increasing/decreasing brightness to blow out white/crush black - and make much of the image the SAME)
Scott -
using in virtualdub plugin ffinputdriver plugin based ffmpeg to resolve all problems import file to virtualdub
download plugin http://code.google.com/p/ffinputdriver/downloads/list
small size convert to xvid or mpeg4 and audio mp3 or lame
very small size with codec x264vfw
Fastest MKV Video Conversion?
By Datson in forum Video ConversionReplies: 7Last Post: 20th Jan 2012, 23:11 -
Easiest, fastest way to convert MKV to Blu Ray with 1080p aspect ratio
By jfk8680 in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Apr 2010, 00:07 -
How Can I Convert Video to MKV with a smallest Size?
By MKV Only in forum Video ConversionReplies: 8Last Post: 24th Mar 2010, 17:17 -
Advice on acheiving the fastest mkv conversion
By animlchin in forum Video ConversionReplies: 6Last Post: 19th Dec 2009, 19:21 -
HELP: Looking for fastest mkv to mp4 converter
By fletch407 in forum Video ConversionReplies: 1Last Post: 21st May 2008, 18:11
