I need help figuring out how to optimize a few clips recorded with a handheld digital camcorder.
I've identified the clips to be 720x576 interlaced PAL, 25fps, MPEG-2, TFF (top fields first), DVD "VOB" format. Here's one of the clips for reference (download for best quality): https://www.dropbox.com/s/fcg38d3mxts1ubw/M2U00663.MPG
I've done some researching but I find this a bit complicated. Anyway, my hope is to deinterlace these clips using the BOB setting and, if this is possible; upscale them to 1280x720. Then edit them together in a video editor.
So, where should I start? What types of software do I need to preform a BOB deinterlace (preferably free or "borrowed")? Should I wait with the upscale until I'm finished with all the clips in the editing software?
Some programs can't work with these clips so what format should I convert the clips to for best quality?
I'd appreciate any help I can get, but please keep it simple for a beginner. I hardly understand half of what I've written here...
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
What do you intend to do with the result? Use it in an editor? Just watch it? Upload to Youtube or some other video sharing service? Upscaling to 1280x720 won't make it HD. It will just give you a bigger fuzzier picture.
The best smart bob deinterlacers is QTGMC() in AviSynth. One of the best upscalers is nnedi3_rpow2()*, also in AviSynth. I would use those two filters along with DgMpegDec to decompress the MPEG 2 source. But getting all that set up and learning how to use it is a bit complicated.
* Though it would be wasted on this video given how blurry it is.Last edited by jagabo; 19th Aug 2012 at 19:00.
Yes. It doesn' t make any sense to upscale before, unless you have other HD material to combine with. If all your assets are SD, upscaling before just makes editing slower . Also you might waste time and processing upscaling material you 're just going to edit out anyway
But you should answer jagbo's questions first as to why you are doing this - usually upscaling doesn't make sense in the first place. There are usually more negatives than positives, but there are some specific scearnios where it might be beneficial
Some programs can't work with these clips so what format should I convert the clips to for best quality? -
I'm going to make a Showreel, out of a bunch of short 5-10sec clips, to send to people, show on HDTVs and maybe post on Youtube. I realize my source material isn't that good but it's what I've got and I want to make it look as good as possible. So deinterlacing and maybe some other cleaning filters is what I was thinking to try and salvage and spruce up the clips.
I don't know how good 480p will look on Youtube compared to an upscaled version at 720p.. But aren't you limited, size wise and/or bits/frames wise, if you don't go HD (or "HD" in my case)? That was my main reasoning regarding upscaling and that it might look better on a HDTV screen(would it?).
Also, do I need to think about Telecine if I deinterlace? Don't want that ghost looking effect..
I'm just starting to learn AVIsynth now so tips regarding filters and such for these particular source files would be much appreciated.
I was trying out Premiere Pro and it wouldn't work with this clip. But now I know about AVIsynth that souldn't be a problem any more right?Last edited by p1er; 19th Aug 2012 at 19:48.
Hahaha are you guys making a "Jackass" movie Looks fun
If it was only for youtube, bobbing doesn't make sense (youtube only supports 30p , or in your case you would use 25p), but if you were playing other files on a PC, then bobbing might make sense .
You can make a case of upscaling for HDTV, if the software upscaling is better than the native HDTV upscaler. On your clip it would probably only make a marginal difference . You might try some small comparisons, to see if it's worth the extra effort (processing time and larger filesizes required for a certain level of "quality")
"ghost looking" effect usually only occurs when you do field blending conversions, or blend deinterlace - you shouldn't be doing any of these
Avisynth is a great tool and very powerful, but it's not a very good NLE - editing is very "clunky" with it (But it might be all you need if you're just doing simple edits)
Some selective use of slow motion and some creative editing could enhance this IMO
(And consider "censoring" the license plate. In some areas it might cause problems with insurance or law enforcement agencies)Last edited by poisondeathray; 19th Aug 2012 at 20:25.
So will I get away with upscaling the clip without loosing detail? I don't want to make it worse quality wise by doing this but it would be nice for HDTV and to get it to 720p on Youtube.
What other type of deinterlacing than BOB might work for these clips then? I tried deinterlacing using VLC and the BOB version, to me, looked the nicest.
I tried Premiere Pro CS6 and it didn't like my clips. I thought maybe they were too old for such a new program or that MPEG2 was a bad codec or something. Well, with AVIsynth I should be able to work around this right?
I just need to learn how to use it first.. -
Upscaling doesn't lose detail. But it can introduce artifacts, especially on sharp edges. Fortunately for you, your video has no sharp edges, it's a blurry mess.
Encoding your upscaled video is a separate issue. When using lossy codecs you must allow sufficient bitrate to prevent loss of detail, blocky artifacts, and posterization. You can use lossless codecs as intermediates to prevent that loss of detail. But the files will be very large.
It will have a larger frame but it won't be high definition. Nobody will mistake your upscaled video for something shot with a decent HD camera.
As mentioned earlier, the best deinterlacers are in AviSynth. QTGMC() is currently the best for most video. Yadif can be pretty good.
I need tips for Screen Capture (Video) Software
By FallenAngelII in forum CapturingReplies: 5Last Post: 17th Oct 2010, 22:22 -
Optimizing video quality--suggestions? (from Canon Vixia HF100)
By Michiko280 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 27th Jan 2009, 11:10 -
Tips On Optimizing VLC for Smoother Playback in OS X???
By Danteism in forum MacReplies: 9Last Post: 24th Jan 2009, 03:27 -
Recommendations for database software for my home video clips
By lariol in forum Newbie / General discussionsReplies: 0Last Post: 9th Jun 2008, 13:49 -
software to join video clips
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2007, 03:38
