  1. Hey
    How change TS VBR to CBR ?
  2. Reencode with CBR.
  3. DECEASED
    Jun 2009
    Heaven
    OR... remux with an appropriate CBR value.
    Not sure if this is what you want or need, though.
  4. ok thx for help I will try
  5. Member Cornucopia's Avatar
    Remuxing alone WILL NOT do the job. To go from VBR to CBR (or vice versa), you MUST re-encode.
  6. DECEASED
    Jun 2009
    Heaven
