I know awhile back you could get a computer with two processors before multicore processors were the norm.
Do they make DUAL PROCESSORS with MULTICORE processors? So in effect you would have two physical multicore chips on the motherboard. Is that doable? Is it feasible?
So in a sense you could have a twelve core processor then right? A motherboard with TWO six core processors. Is that available? Would it truly be that powerful? Is there anything that could utilize that power in the home arena?
I guess a quick trip to tigerdirect or newegg would answer this question for me but I thought I'd check here first.
Edit - I checked both sites and I couldn't really see anything. I may not be looking at the right thing. I saw the amd phenom 2 x6 and the core i7 (which one is intels six core chip? They have one don't they?).
Also note I'm not ready to buy a new computer yet so this is just curious speculation on my part.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
i was actually thinking of putting together such a system, you can get parts at micro center, but it's going to cost you:
http://www.microcenter.com/single_product_results.phtml?product_id=0388606
http://www.microcenter.com/single_product_results.phtml?product_id=0388582
this would be a 12 core 24 thread beast.
as far as OS support even Vista would fully support it, Win 7 and 8 easily and i'd even bet money that XP 64 would use all the cores.
only thing is that unless you're running very specific highly threaded cpu bound workloads you won't get the benefit you might be expecting. even for most web hosting workloads you usually get much better performance going with a hard ware raid card and a workstation class NIC than using 2 multicore chips, or for most 3d rendering needs a workstation class card is a much better choice.
i would argue that for most users it's never a good idea to build with the top of the line hardware, intel's chips jump in performance so much from one generation to the next that the $1000+ motherboard/cpu(s) combo you just put together will be smoked in most circumstances by the $400 motherboard/chip combo that will be available in the next 6-9 months from the same companies.
in fact after intel reported that the 6 core ivy bridge E class cpu's won't be available until the middle of next year most tech analysts are wondering if intel should even bother releasing such a chip as that is also the time frame for Haswell which is expected to be a monster of a chip (kind of what sandy bridge was to it's predecessors). -
Thanks for the info deadrats. This was more hypothetical stuff that I was curious about. I don't have any intentions of trying it. But its nice to know it should work.
You can also run into trouble with certain multithreaded apps where each thread reserves 'X' amount of RAM. 'X' multiplied by 12 can soon exceed the amount of system RAM you have available leading to unexpected halts or crashes. From reading the developer's mailing list for x264, this has certainly happened to at least one person running a system like the one you propose.
I can't recall the exact details now as I read it a few weeks ago, but the only fix (besides installing obscene amounts of RAM) was to limit the number of threads to less than the number of CPU cores the system had, and that kind of defeats the object of having so many in the first place. I guess the moral of the story is to do your research first before parting with any cash. -
Originally Posted by slipster
Originally Posted by slipsterDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
Intel Cuts Some Quad-core Chip Prices by 40 Percent
By Soopafresh in forum ComputerReplies: 0Last Post: 20th Jan 2009, 13:41 -
Intel Slashes Quad-core, Dual-core Processor Prices
By louv68 in forum Latest Video NewsReplies: 0Last Post: 22nd Apr 2008, 18:14 -
AMD 4200+ Single Core to Dual-Core Upgrade Issue...
By Bodyslide in forum ComputerReplies: 7Last Post: 30th Nov 2007, 15:45
