So I've recorded some stuff on my computer and the file originally is AVI so in Avidemux I just keep the format AVI since it works for and can be uploaded to YouTube. When I convert the file to compress it, since it's raw and takes up 40gigs of my HD each 15 minutes, it won't open up, or display the time, length, and size of the file like the other successfully converted files. The settings are the same as the other's and they work, but this time it doesn't work. There's nothing apparently wrong with the original file since it plays just fine, and it's more than just this file.
Any ideas on what it could be? I've tried converting it multiple times to see if the encoding process just messed up somehow, but it's failed multiple times in a row. Mind you when I rename the file to put the file extension .avi at the end unlike the one's that work this one will only display the .avi file logo on the file as a preview, unlike the others where it displays the beginning of the video.
A 15 min avc at 4 gig !! - your PC is probably choking trying to play that back. It is likely that your avidemux setting are totally wrong.
I can not duplicate your result completely but I notice the lack of a video ID. I can only achieve that if I set video to 'Copy' which is the default setting. That also means your video codec has not changed - it is still uncompressd.
Try this (or even experiment with others)
Set video to mpeg-4 AVC
Set audio to mp3(lame)
Set format to mp4
To get the best out of h.264 you will have to learn all the settings of the codec. No one here will teach you that.
Save the video as filename.mp4
Report back with a new mediainfo report and if the video now plays.
AVI files won't open in Avidemux
By Ahari in forum Newbie / General discussionsReplies: 28Last Post: 18th Mar 2025, 15:22 -
Trying to convert AVI to MP4 (for iPad) -- Avidemux won't install
By monkeypack in forum Video ConversionReplies: 4Last Post: 28th Nov 2011, 09:18 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 11:10 -
Avidemux won't open mov
By Nitro89 in forum Video ConversionReplies: 2Last Post: 13th Apr 2008, 10:46 -
Nero won't open .mp4 file
By ChickaJane in forum Video ConversionReplies: 8Last Post: 22nd Aug 2007, 00:38
