I'm caturing from a WinTV board with irVCR which was recommended because I have XP. Need to capture for 1 hour. If I capture uncompressed, everything's fine but I end up with a 60 GB file. Huffy codec causes a gradual A/V sync problem that gets progressivly worse. At the half-hour point it's off by about 1 sec. Since it doesn't happen uncompressed it must be Huffy. Any suggestions?
make sure you are using PCM 44Khz 16bit Stereo - if you were, try setting your master stream in iuvcr to audio
or set your audio compression to:
PCM 48Khz 16bit Stereo (then convert when encoding) -
Followed your suggestions. Was already capturing PCM 48khz 16 bit. Enabled master stream audio. Didn't help. Then enabled "sync using stream offset". That did the trick
Thanks for your help!!!
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
I want to dub both audio files to the same movie but sync problem
By amdsamurai in forum Newbie / General discussionsReplies: 7Last Post: 5th Feb 2011, 08:03 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
StaxRip audio sync problem creating MKV files
By ejai in forum DVD RippingReplies: 0Last Post: 24th Apr 2009, 15:16
