I really don't know how to ask this so I will try to do the best I can. I am not real happy with the capture on my Sony Vegas Pro 11 at this point. It has been having several glitches and I was wondering what is an alternative to this? Pay or free is not a concern. This is the starting point and only part of my question. I also have a Canopus ADVC-50 A/D CONVERTER for capture with firewire. I was wondering if this is a good enough product for the capture of HD anymore? Is there a better alternative than using firewire and this device? The camera I have is the Sony HDR-FX7 that uses mini DV. I am sure I left something off but if you can figure out what I mean from this please give me a little help if possible. Thanks.
As for glitches, I could not import a part of a capture. I had 112 pieces to the capture and #64 kept on causing SVPro to crash. I did not add it and all of the other 111 media clips from the capture worked. I can't get it to recognize the camera sometimes until I unplug it and re plug it back in. Just little things like that. When it puts the media in the bin after capture it is sometimes out of order so I have to go and arrange it, which sucks when you have over 100 clips.
When you say converter what do you mean? Are you talking the Canopus? I have been told that Canopus is a great device but what do I know. Please explain and tell me what I should do to capture or what you do. Do you use firewire? I was reading somewhere that a guys thinks that is a bad way to capture. Thoughts? thanks. -
The ADVC-50 is a standard definition capture device. You can't get 1080i into it, or 1080i out of it.
Canon hv20, 24p hdv, and recommended capture method?
By joshcali in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 4th Mar 2012, 19:28 -
Deinterlace 60i -> 60p, yes, 60p, not 30p.
By 123Mike in forum Video ConversionReplies: 20Last Post: 4th May 2009, 13:43 -
Watching HDV footage - 1080i CRT vs. 720p LCD
By JohnnyMalaria in forum DVB / IPTVReplies: 12Last Post: 21st Feb 2008, 02:29 -
Mpeg-2 HDV 1080i to Final Cut
By The Sumerian in forum Video ConversionReplies: 2Last Post: 12th Dec 2007, 23:07 -
HDR-HC1E 1080i HDV -> MP4 PS3???
By tobyed2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 2nd Nov 2007, 12:37
