I'm trying to make subtitles using VirtualDub, so far I've gotten to the part where I need to make a .vdr file.
So far I've been stuck at this screen for awhile now.
Is it actually doing anything? How big will the vdr file be once it's complete? (I only have 1.2GB left). How long is this supposed to take?
All the numbers are staying at zero too by the way. Is that supposed to happen?
Once you start the frame server, it won't do anything until you open it in another program (start encoding in TMPGEnc, for example). When you frameserve, you're not creating an entire new movie file, so the file will be very small. And that's the beauty of it.
Need Help about Professional Subtitling
By kei_siuip in forum SubtitleReplies: 1Last Post: 14th Mar 2011, 04:04 -
Subtitling on the Mac
By sky captain in forum MacReplies: 2Last Post: 12th Jan 2010, 14:16 -
mkv subtitling
By eliqush in forum EditingReplies: 6Last Post: 19th Jun 2009, 04:11 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 11:43 -
Subtitling. Thanks in advance.
By shr3dd3r in forum SubtitleReplies: 4Last Post: 11th Sep 2007, 15:21
